Vacuum Pump Help from users
Dick Wilson
A friend has a vacuum pump that he has an issue with. The hose that comes out of the head stock to the filter turns black. He can't figure out where the black "graphite like" material is coming from. It clogs up the filter. Obviously it is not good for pump. Have any of you had this problem and what does he do to illiminate it???? Thanks.
Re: Vacuum Pump Help from users
Doug Wolf
It sounds like he's using black ABS pipe fittings for his vacuum chuck which emit particles when under a vacuum. Use schedule 40 White PVC fittings for vacuum chucks.
Keith Newton
If it is a rotary-vane type, it could be the vanes wearing away. Ihad one years ago, but hated it because of the noise.
Chuck Jones - West TN
That was my first thought also, but the dust from the vanes would be coming out the exhaust of the pump, not the lathe headstock.
If your talking about the headstock to the filter then it has to be either the hose or the bearing or some other connecting piece. It could even be vacuum chuck or gasket material. Remove the chuck and just put a piece of wood plastick over the spindle and let it run. that will tell you if it's the chuck. It could easily be the gasket material.
then remove the hose from the bearing and cap that off. that would answer if it's the bearing or not.
I've heard stories of some sealed bearings not sealing well enough for vacuum. I have not had any problems with the 2 systems I built and I thought I just used run of the mill sealed bearings.
Don Evans
Dick:
First, is this a shop made system or was everything purchased from a manufacturer? An example would be it has a Oneway adapter on outboard threads and uses their aluminium drums to hold the wood.
Also what does the black stuff look and feel like? Is it greasy like graphite or is it dry and hard like plastic or rubbery etc.
Is there damage to the material that seals the drum to the wood? I'm thinking possible sliping but turner is using tailstock for support at same time as vacuum and may stop wood if too heavy handed and grind the rubber or whatever is being used.
MOST IMPORTANT - let us know what final result is, so many times we never hear the final answer and no one learns.
Don
Dick Wilson
Here is what I know. It is a new Gast vacuum pump with 30 minutes of run time. The black sooty material is on the opposite side of the filter as the pump. He has contacted Gast and they are well aware that their pumps are used as vacuum chucks by us turners. I believe he said the filter was purchased from company in Australia. I think he bought the parts and assembled it himself. He has a Powermatic. I don't know what the vacuum chuck is made out of. When I find out from him what the problem is I will post the findings and the solution.
Thanks guys for mulling this problem over and sharing.
