Do bugs get dizzy?
Do bugs get dizzy?
Do bugs get dizzy?
avalon
So i'm standing at my lathe working on a bowl (at 2am) when bug bits start hitting my shield.. and it occurred to me ..
Why dont bugs, larvae, etc, get mooshed against the wall of their tunnel when an object is spinning at 1500 rpms..
A typical person can handle about 5 g (49 m/s�) before losing consciousness ("G-LOC"), but through the combination of special g-suits and efforts to strain muscles�both of which act to force blood back into the brain�modern pilots can typically handle a sustained 9 g (88 m/s�). We can handle more gravities, but can a bug?
So i assume that 49 meters traveled in 1 sec= .03045 mi sqd. = .0009272x=5 gravities. ( dont think i did this one right)
letsee if i can follow the math..
if a bug lives in the outer part of a 24 inch circumference and the lathe is turning at 1500rpms...
24x1500=36,000 /12 =3000ft per minute distance or 0.568181 mi or roughly 30 miles per hour..
course i dont think the speed is the same at point A (where bug is) and at point B (center of axis of turning)... but lets not bother with that...
dont bugs splatter on a windshield at 30 mph?
so Newtons Second law: The acceleration a of a body is parallel and directly proportional to the net force F and inversely proportional to the mass m, i.e., F = ma. Ie... if you turn on the lathe and it goes to 1500 rpms really fast, the smaller the mass the less force is applied to bug in tunnel?
i'm trying to figure out how to convert the circumference x lathe speed = how many gravities..
yes mr tabor... this is what i think about at almost 4am... I was turning at 2am... (mr tabor is sorta my local guru...)
i actually think im rambling.. bed time...
Re: Do bugs get dizzy?
avalon
since im a liberal arts major, i do not claim any of the math in the previous message to be correct, valid, or even rational.
Early-morning math: 107mph
Opelika Edro
Perhaps not a good idea to do the early-morning math, but I get, for your 24in diameter piece (gulp) at 1500rpm (yikes), 107mph at the outer edge with 766g centripetal acceleration(!).
Using the same method gives for a 12in diameter piece at 600rpm, 21.4mph and 77g. That's more my "speed". :-)
The rim speeds make sense wrt each other because yours is 2x diameter and 2.5x as fast, or 5x the product. Your rim goes pi*diameter=75.4in per rev (circumference is pi*diameter). Then
(75.4in/rev) * (1ft/12in) * (1mile/5280ft) * (1500rev/min) * (60min/hour) = 107mph
The acceleration numbers are hard for me to get a feel for, not that I have much to go on. But if you think of one of those "gravitron"-type carnival rides that spin you up to simulate higher gravity ... seems to me maybe 20ft across and say spinning you up to 3g ... that would be about half a rev per sec, or 2sec per full rev.
If you buy the rim-speed calculation, the centripetal acceleration is rim-speed squared, then divided by half the diameter, and converted to g using 32.2ft/sec/sec. Or something.
Steven Antonucci
Up early myself...
steven antonucci
but I went back to sleep.
Some things to considers:
Gravity acts on a mass to create a force (F=mA). A bug has very little mass.
Bugs splatter on the windshield because the car is typically travelling 50mph and it has a lot of mass. When a bug flies into a building, it typically applies very little force because it is not accelerating.
I would have trepidation about being near a 24" bowl blank spinning at 1500 rpm.
I forget the exact formula for rotating bodies, but google is my friend:
http://pacer.calpoly.edu/tri/pacer/gforce.html
Given that it is a rotational acceleration, I assume that the bug is quickly pressed against the wall like the carnival ride. The bug likely has a millisecond to accelerate and can only travel a short distance (it's tunnel) before it experiences 10x it's own weight,which is next to nothing...so it survives.
Now, as to do bugs get dizzy? I don't know...
S
Alan Zenreich
Re: Early-morning math: 107mph
Alan Zenreich
I think you're looking at the wrong factors.
Instead of concerning yourself with centripetal forces, when dealing with bugs, you should be investigating potential centipedal or perhaps millipedal issues.
The real question is whether to bolt all those legs to the shop floor.
Dale Jablonski
Re: Up early myself...
Dale Jablonski
Do bugs get dizzy? I suspect that they must when spun on the lathe. One thing for sure is that they do get you messy when you expose and then depose them with your chisel. Especially those large beattle larvae.
Ric Taylor
5 Gs is Nothing
Ric Taylor
When I was flying, I went close to 9 Gs many times. And quite a few times I went in excess of 7 Gs without a G-suit.
Bugs that are already riding on a windshield do not splatter at any speed. Your bugs are riding in a piece of wood.
Ric
safety issue
Mike from St. Clair Shores
A 24" bowl is going 3x faster than is safe at 1500 rpms. So the real question becomes, "how dizzy are you going to be when that bowl flys off the lathe and hits you in the head".
Hope it never comes to that.
Please stay safe.
Mike
Richard Allen
Richard Allen
Avalon said 24" circumference not diameter. The diameter would be less than 8".
Yes
GolfSteve in Calgary
While working a job in small town Saskatchewan one of the labourers spent his breaks sneaking up on, and catching deer flies in his hand. He would then shake them up and let them go. They would spin circles for about 5 seconds before getting their orientation.
This was a bit cruel, but he would also take the small wires that break off wire wheels - you know when power brushing the wires always break off and usually embed themselves in your cheek or your belly button. After catching a deer fly he would embed the wire up the fly's rectum and let it go. It would spiral straight up with it's bum drooping straight down for about 5 seconds then fall to the ground dead.
Man those were the good old days :-(
Bill Turpin WNC mountains
The important question is not dizzy bugs, it is, "Are dizzy bug guts harder to clean off your faceshield than non-dizzy bugs?" Who cares once they are on your shield.
Also take into account that it's not......
JamieDonaldson
...not so much the speed that counts, but how quickly the deceleration that counts. Freefall while skydiving is just like the bug about to hit the windshield, it's the sudden stop that hurts! :b
Dale Jablonski
Re: Yes
Dale Jablonski
As painfull as those are when they bite I say way to go!
Opelika Edro
So he did! Nice catch -- I shoulda read more carefully. Ahem. :-)
