To bolt or not to bolt, the lathe
Don Leydens
I'm thinking of bolting my 3520b Powermatic to the cement floor in the shop. I'm tossing around the idea of 2 metal plates with a chunk of rubber in between them which will go under the legs and attached to the floor with bolts running from the lathe legs down into the floor.
I've read somewhere that people were worried about a direct attachment to the floor because it might cause the cast iron legs to crack, but have never heard of this happening to anyone. I'm thinking that a good sized piece of rubber in between the metal plates will allow for a little bit of "give".
I'm not planning on turning any car sized chunks of wood, but would like to stop the occasional walking of the lathe.
Any ideas or comments would be more than welcome. Thanks in advance,
Don
Imagine walking through this maze every time you went to the grinder. It would then function as a weight loss device and possible get Government funding.
