Project from you know where is done.
Here is the router plane with fixes in place. It came out quite nice. The top and bottom are turned on the after drilling all the holes and bandsawing out the rest of the shape. I turned a walnut plug for the 2 1/8" hole and then drilled it out to 2". I thought that and the walnut bottom came out quite well.
the cutter is a 3/8" allen wrench. It was a bear filing out the 6 sided hole in the thumbscrew to hold the wrench. I noticed this morning that I need to file one of the flats just a hair more. I actually have a blister on my middle finger from holding the small file.
the other tool is a socket chisel I picked up this summer. I cleaned all the rust off and built a rosewood handle for it. Calculating the taper for the socket was fun. I put drill bits in until I found one that exactly fit the bottom. then measured the depth. then I measured the big end and had the 3 dimensions I needed to turn it. It fit so well I simply dropped it in the hole and tapped the end with a mallet. I could not pull it back out so I left it.
