Looking for a toolrest
Mike Cunningham
I'm looking for a 16"+ toolrest with a 1" post. CS has a Powermatic 16" in their catalog but a call revealed that they no longer carry it. Anyone know of a source for 16" or longer?
Thanks
Mike Cunningham
Thanks
Call Brent at Robust lathes
He made me a custom sized rest but I haven't asked for something like that. I would be interested. I love his tool rests and if he offers a 16 I would be interested.
I wouldn't use a rest that long .....
JamieDonaldson
....without 2 banjos for support. There could be too much potential flex out on the ends of such a long rest, and that would induce chatter as well as be a safety concern.
Re: Looking for a toolrest
Katherine Kowalski
I definitely second John's recommendation to call Brent at Robust. He made some very nice tool rests for me for my production work. (8" comfort rests with a post for a mini-lathe -- brilliant!)
However, I would like to caution you about requesting such a long rest. Allan Batty recommends that tool rests be NO LONGER than 8" long (with a single post). Even the "standard" 12" is far too long. The reason? Vibration. If you are turning on the end of the rest, the rest will flex, and your tool will bounce.
Consider getting a rest with TWO posts, or making your own rest from a bit of wood. (There was an article in Woodturning recently about making a rest this way -- installing a post in a bloc of wood, then clamping the other side to the tailstock for support.) This, of course, was for doing long spindle work.
Consider investing in a second banjo for your new rest.
Katherine
How about with a different "shape"?
Like more of a triangular shape?
I agree that a regular bar or rod tool rest would probably flex. But if it had some sort of "webbing" supporting the extra length, it might work.
Make one
steven antonucci
If you have any of the modular rest, just get a steel bar and drill and tap it to fit. A second banjo is a good idea, but it can be as simple as a wooden block that you attached to the lathe with clamps.
I made one that is 36", and it works great.
S
Here is one of my favorite.....
Mike Stafford
homemade tool rests. (Said with tongue firmly planted in cheek)
Your tool rest length is only limited by the length of the pipe you have available....
Re: Here is one of my favorite.....
Mike Cunningham
Yikes!
Thanks
Mike Cunningham
I'll do that. I have a 14" Oneway and need just a bit more...
Greg Haugen
Mike,
Is that for reaching inside of those "signature" boxes? :-)
Is that kind of like, "You need 9 chucks to get anything done". :-)
Actually
Mike Cunningham
I just checked the Robust site and they manufacture and sell a 15"...............thanks.
Holy Cow! Look at those exposed wires!
steven antonucci
Must have been done by someone with an Electrical Engineering degree, but at the bottom of his class
In case you didn't recognize the source, that is long tool rest #1 in my shop. The left side fails to show the deadman supporting the long pipe, which was filled with cement and plugged with oak dowel to dampen vibrations. You would be surprised how well this worked.
My new one is made from a 1" thick solid steel bar, tapped and threaded to fit a commercially available tool post. The other side is still supported by the outrigger, since I haven't made a second wooden banjo for it (rarely used).
Long tool rest #2 cost me $2 to make.
S
Re: How about with a different "shape"?
that's why I like the Robust rest. The semi circular shape is very stiff.
Re: Holy Cow! Look at those exposed wires!
Mike Stafford
Obviously I did not recall that this was your tool rest Steve. Had I remembered I would not have posted it.
Just poking you in the ribs a little....
Sorry if I offended you.
no offense taken.
steven antonucci
and i'll reaffirm that it works well...
S
Is that lathe battery operated?
Mike from St. Clair Shores
Back-up DC power...
steven antonucci
or just a convenient place to store the battery for my rowboat trolling motor.
S
Re: Call Brent at Robust lathes
Mike Cunningham
His tooling prevents him from fabricating greater than 15", so 15" it is. Thanks........
