Where to buy paraffin or sealing wax
Bill Tucker
Looking for a reasonably priced source for paraffin or sealing wax. I thought it should be easy to find with the canning stuff and fairly inexpensive. My how times have changed! Not much canning in Nashville, but lots of beauty enhancements. Can't find the old paraffin brick anymore, but lots of soft beads for ......whatever. This is starting to head down the path of fly-tying turkey feathers.
Oh well - any help would be appreciated.
bill
Re: Where to buy paraffin or sealing wax
I don't have any trouble buying it at the grocery stores here in Cookeville. I shop mostly at Kroger's and FoodLion. They also have it at my local Spring St. Market. I don't know what the cost is. I usually buy it in a pack of 3 and seems like it's pretty low cost. 6 sticks go a long way when I'm sealing ends of logs and spindle blanks. It goes pretty far when I seal whole bowl blanks.
Bill Jacksonville, NC
My wife buys GULF WAX, HOUSEHLD PARAFFIN WAX FOR ME at base commissary. Wal-Mart in my town did carry it too!
You can: check store availability and price on-line.
walmart.com/ip/Gulf-Wax-For-Canning-Candlemaking-Many-Other-Uses-Household-Paraffin-Wax-16-oz/10420578
David DeCristoforo
Don't buy it from the grocery store or the hardware store. Go online and search for candle making supplies. there's tons of vendors and ten pound paraffin slabs can easily be found for around twenty bucks apiece.
John Leonard
Try Holly Lobby in the candle making area.
GARAGE SALES!!!
George Guadiane
I just bought another three pounds of candles (one of them was new) for $1.00
People light them once or twice and then lose interest. Canning wax can cost as much as $6/$8 a pound at retail stores. Even at half that from on line sources, when you add shipping, it'll be $4 or more.
Buy just white (clear) ones and you'll be able to see the surfaces you are protecting. Colors make it impossible to see the wood.
Chuck Jones - West TN
Hobby Lobby 10 lbs $18 - sometimes on sale
Bill Tucker
Thanks everybody. Just wondering, has anyone tried vacuum bagging? If so, how well did it work?
Nick Tuzzolino
General Wax and Candle Co. generalwax.com I got what is called Houseblend #140,very clear so you can see the grain. $26 for 24 pounds in 1# blocks. $10 shipping. Buy with a buddy or give some to your friends and feel like a rich guy :D.
what about beeswax?
avalon
i have 10 beehives at my farm and have not had a chance to get any wax yet, but was wondering how beeswax would work...
Plastic wrap
Bill I have not tried vacuum bagging but have used Plastic wrap. It's the kind you buy in large rolls to wrap merchandise for shipping. It seems to work as well as waxing but i'm still to new to using it to tell you for sure. It certainly is quick and easy.
Re: what about beeswax?
Bees wax will work fine, just too expensive for folks without hives.
Completely sealing wood in vacuum plastic bag will not allow wood to dry. Depending upon MC at time of vacuuming could encourage mold to growth. It is true if completely seal wood in wax, water in wood has no place to go. End sealing allows wood to lose moisture slowly.
If you live in an area with high relative humidity plastic bag and wrap may encourage mold and blue spotting in long term storing. People in arid parts of the country have better luck with plastic bags and wrap.
I Concurr
George Guadiane
Bill for me, not drying is the whole idea. I'm trying to prolong the saving time until I can get it roughed out. So far the only mold has been light and on the surface but then I have not let a piece sit for more than a few months.
With the Wax I have let a piece sit for 2 years and so far no mold on those at all. The wax does start to crack and the pieces are losing weight so they are drying.
melting point and flash point
Be aware that the flash point and melting point of different waxes are different. The Parafin wax that I use has a melting point of 140 degrees and flash point of 480 so it's pretty safe to use in an electric skillet like I do. Even so I keep lid handy and fire extinquisher handy.
Other waxes may have the 2 points closer together which could be dangerous. In that case use a double boiler to melt your wax. Just don't tell your wife you've use the chocolate melter to coat your logs.
Re: melting point and flash point
George Guadiane
John,
You have brought up an important point!
I have no way of knowing the flash point of the candle wax I pick up at garage sales, so I try to keep the temperature "just hot enough." I too keep the cover right there, and I'll add the extinguisher to the party.
I suggest that we assume the flash point is MUCH lower with waxes you don't know about for sure.
