OT *LINK*
OT *LINK*
OT  *LINK*
Mike from St. Clair Shores
I saw this video on You Tube, and I immediately wondered if Charlie Belden had seen it. It is very cool, but out of the average persons price range. It is a 3 D printer. You won't believe what it can do.
3 Dimensional Printer
Re: OT *LINK*
Steven Antonucci
Can they print in wood?
steven antonucci
I'll take one that prints in ebony and cherry burl, please...
S
Re: OT *LINK*
Re: OT
Curtis Thompson
When they can reproduce a Rally's burger, give me a call !! :D
Re: OT *LINK*
Re: OT
charlie belden
Actually - there's a $1,200 model, a little less for a kit. The size of the "printed" object is limited - and it doesn't do parts that move all in one print job. The "printed" 3D objects show the extruded layers, in part because of the "print head/extruder" limitations and in part because of the extrusion material. But like computers, prices keep coming down and the capabilities keep getting better.
But you don't have to OWN an expensive 3D printer to USE one. There are 3D printer service outfits that will, for a fee, take your 3D mage file - print a 3D copy and mail it back to you - for about $50. And like computers, the price is coming down as the quality of the results keep getting better.
I saw a 3D "scanner" at a recent Makers Faire that uses a Micro Soft 3D "camera" they developed for their game boxes. They used it to detect movement and translate the data to use as a controller for some of their games. I was told that you can find one of these things for about $150. There are Open Source programs that will take the data and convert it into one of several 3D computer file formats that 3D printers can use.
Artists and artisans are always finding ways to use new technology -or adapt existing technology - when the price of admission comes down.
We live in interesting times.
Re: OT *LINK*
Re: OT
Steve I wonder if the 3Dprinter could print texture and color to make it look like wood. I was thinking of the chinese puzzle balls.
Curtis, that day is probably not to far off.
Charlie, I just knew you would know all about this. I still can't believe what I saw in that video. The printer could make all the parts needed for embellishment on turnings. Like the wood that bends at flutedbeams.com Have you studied lithopanes? There are so many amazing technologies out there. I read all your post to try and keep up.
Mike
Re: OT *LINK*
It's interesting that it has take this long
I went to a seminar almost 15 years ago. They handed out a miniature set of slip joint pliers that were made this way. Somewhere along the line I lost them. I have been fascinated by the process. About 10 years ago I photographed a machine called a rapid prototype machine that used the same process. They showed us how they had made an IV hose clamp. They made one and gave it to Nurses to try out. Then the next day made another one based on suggestions by the nurse. Several days later after several more prototypes they went into production. Wish they could do that with lathes.
Re: OT *LINK*
Re: It's interesting that it has take this long
I heard that Jay Leno (Car guy and from the Tonight Show) has a 3-d printer he can use to produce car arts. Have no idea what it can do, but it would interesting to know.
Re: OT *LINK*
Barry I haven't read about it yet but I'll bet it won't be long before they use the same technology of the particle metal tools and make metal parts. I'm sure it would take new type of print head because the metal particle are probably too large and certainly more abrasive than plastic.
However that doesn't mean you can't make a lost wax casting this way. That would really be cool for home use. Make a wax form, then create the mold and then make the part.
Re: OT *LINK*
I saw one on one of the How Do They Do That type shows. As I recall (take this with a grain of salt, I do not recall this all that clearly) they were making a copy of a very elaborate "dragon" type drawer pull. I think they had an original and they did a 3-D scan. Then they printed this thing in a bed of metal particles (Stainless Steel particles??) mixed with some sort of binder powder. The laser glues the stainless particles together by fusing them with the binder. The thing worked by having a thin layer of the media and then lasering what ever would have been on the bottom, then they added another very thing layer of media. It sort of squeegeed it into place by lowering the platen and closing and opening as if it were a drawer. Then the laser applied the second layer and they went again and again until they had built up the entire piece. The interesting thing was that by this time, they piece was buried in the surrounding dust. The operator reached in and carefully fished it out and then cleaned it up equally carefully. Then they fired it which burned away the binder and fused the SS. Then they cleaned it up a bit more and gold plated it.
I have also seen one that worked in plastic. The same principle. The platen was suspended in a bath of liquid plastic, just below the surface. A UV laser hardened the first layer. The platen dropped a hundredth of an inch and the laser layed on a second layer and so on. They could make things like the body of an electric drill to see if it fit in hand well. I don't think the parts were tough enough for any real use.
Re: OT *LINK*
Re: OT
charlie belden
Hadn't come acrossed lithopanes, but have seen porcelin pieces that use the idea - a twist on painting opium bottles - from inside. I can't think of a way to use the idea in wood - wood being opaque unless really really thin - too thin to machine a low relief pattern in.
New toys coming on line every day - and prices keep dropping while capabilities keep getting better and better.
Re: OT *LINK*
Re: OT  *LINK*
Charlie,
Check out this video. A turning friend of mine is making one of these. I think they are way cool and love the end result. You could easily create family heirloom lamps etc.
mike
cnc wrapper lithopanes
