It went boom..
avalon
And left a dent in my metal ceiling..
Turned a piece of wood a bout 3 months ago, made a vessel and cut in half to hollow out... I bored out the whole thing with a forstner bit before that, and tried using sorby's hollowmaster to carve out the insides... it took a long time and then it developed a crack and i put it aside to figure out what i wanted to do.. i now have a jamison hollowing rig,,,.. so...
i put the bottom on the lathe, filled cracks with sawdust and ca, turned it back into 9.5 inch diameter round, put a 24 segment of paduk on and shaved that one down to about 1/8th inch thick...
then i made a 24 segment of alternating maple and walnut, left them about 5/8 ths inch tall, and set aside..
made another paduk ring, intending to do same as first ring, so i would have a thin band of paduk, thick of walnut and maple, and another thin of paduk to hide the fact that i cut the vessel in half..
Then i took the top part, glued the top opening to a waste block, rounded the outside back to true, and proceeded to hollow out the inside....with the jamison tool....after about 5 minutes a 45 caliber pistol went off near the bowl which then proceeded to hit warp speed and disapear from this dimention. loud bang, no bowl,,,its gone...
i search the shop and found one section behind the air compressor....another by the base of the lathe, but the third eluded me for an hour,,,, finaly found it in the rafters of the roof, next to the dent in the ceiling it had made.
I was out of the line of fire, but it scared tthe fecal matter out of me,big noise, bowl shatters and dissapearsd, and leaves dents in metal.
our local guys said i was turning to slow, and was getting chatter, so i cranked it up to 1500 to turn all this. Apparently that crack was really bad and caused it to expode,,so speed was the culprit...plus a crack
so what;s the general rule of thumb in turning regarding speed?
how fast when turning bark off, how fast to shape, how fast to use a bowl gouge, how fast to run out of the shop whne something goes wrong...
I'll try to send photos tomorrow.
