A55 Smoothing Plane
OT - Alternative to Adobe Acrobat
dick gerard
I am looking for a way to create PDF files. Purchasing Adobe Acrobat at close to $500 is out of the question.
Anybody have any suggestions for the budget minded?
Re: OT - Alternative to Adobe Acrobat
Mike Brazeau
I downloaded a free pdf printer from bullzip.com about six weeks ago. Seems to be working fine. I have used to print regular files and web pages with no issues.
Ed Moore in SW VA
Dick,
I have MS Word 2007 on my computer. It allows me to save documents as PDF files.
I checked Open Office, a respected alternative to MS Word, and that option does not seem to be available.
Ed
Allen Howell
Where I used to work, they used CutePDF to write pdf files and it seemed to work well. I think it is free for commercial and non-commercial use. Google it and you should find it.
Free - Look to PDF print drivers
Craig Daymon
Dick,
I am running Linux and can generate a PDF from any program that allows me to print. It doesn't cost me a dime.
LibreOffice, the non-Oracle version of OpenOffice, allows you to export any document to PDF. This includes their word processor, spreadsheet, presentation package, vector drawing program and database. Depending on what you need, this might be a good solution. (To my knowledge, the windows version exports to PDF as well.)
http://www.libreoffice.org/
Another, possibly more useful, option for you might be one of the PDF printer drivers available for Windows. Most, if not all, are free. Installing one of these, you just select the PDF printer when you go to print and, like on Linux, you can generate a PDF from any of your current programs. I've used PDFCreator before on Windows systems.
http://sourceforge.net/projects/pdfcreator/
Here's another one.
http://www.cutepdf.com/products/cutepdf/writer.asp
One thing using a PDF printer driver is useful for is to print websites where you find useful information. I have PDF files of several WoodCentral postings that I wanted to keep for reference.
-Craig
P.S.  LibreOffice/OpenOffice
Craig Daymon
In LibreOffice, as I believe is still the case for OpenOffice, "Exporting as PDF..." is found under the File menu separate from printing, but is not listed as a "Print" option. The result is the same, you get a PDF of your document.
Stuart Johnson
In Open Office under file is the option to export as PDF. It works well.
Harry in Beautiful Downtown Kulpsville
Google pdf995. It allows you to edit a document in any of the programs you would normally use. But instead or "Saving" the document, you select PRINT. In the list of connected printing devices you will find "PDF995." Selecting that as your printer will allow you to save a PDF file of your document. It works really well...and it is FREE!
Jim DeLaney, Austintown, Ohio
Cute PDF *LINK*
Cute PDF is a printer driver. You select it as your "printer" and it formats and saves whatever you want to print as a PDF.
CutePDF website
John Peck
PDF Create 7 and PDF Converter 7, both from Nuance, and $49.99 each
Greg in Oshkosh
Open office is a free Office suite from SUN which includes a word processor that allows you to save documents as a pdf. I have been using it for my newsletter for a couple years. Works well.
http://www.openoffice.org/
Re: OT - Alternative to Adobe Acrobat *LINK*
Juergen
Try PDF Redirect. It allows one to merge several PDF Files and does not require the seperate installation of the open source Ghostscript program. I've noticed several of the other free PDF writers don't create the thumbnail view of the the file. Also PDF Redirect facilitates saving the file to any forder on your hard drive.
PDF Redirect
Oracle bought Sun
Craig Daymon
Sun no longer exists. It was bought by Oracle, a company that is not a fan of open source. Though OpenOffice is still avaiable, the open source community split off a branch of the software and created LibreOffice. It is identical to OpenOffice, up to the point when Oracle bought Sun. There will be a lot more people contributing to LibreOffice than to OpenOffice now that this has occurred. You should consider switching.
You are absolutely correct!
Ed Moore in SW VA
In MS Word, one uses "Save as" to create the PDF file. So, I looked there in Open Office and did not find it, so I made the obvious incorrect error.
Under "file" it plainly says "Export as PDF .."
Thanks for noting my oversight,
Ed
