THE WOODRAT IS BACK!
New tools I made
New tools I made
New tools I made
I'm doing a tool making demo for a flat woodworking club. I've needed a marking knife and a carving gouge that fits the size between 2 of my smaller ones so built those two. Then I decided I needed a scratch awl so I built that.
I used tool steel for the blades and brass screw on to sweat on copper pipe adaptors for the ferruls. The brass fittings turn very nicely with the Thompson tools. In fact I was able to turn the wooden handles after turning the brass without ever sharpening the tool.
Re: New tools I made
Steven Antonucci
How did you grind the gouge?
steven antonucci
I want to make a few, but I haven't come up with a way to mill the flutes that cleanly. Lots of filing and sanding?
S
Nice looking tools...
GaryG in MD
John, When you're turning brass, what kind of cut(s) do you use? Push? Pull? Shear? Shear scrape? What seems to work best? At what level do you start sanding? etc... Just curious... ...Gary
matt overton
I think those flatwork guys are in for a treat. Beautiful work, John
Mike Brazeau
Very nicely done John. You mentioned a skew you hade made from a 3/8 or 1/4" spade bit the other day. Do you have a photo of that by any chance?
Steve Kubien
Nicely done
Steve Kubien
Very nice work John. Now, what is this "flat woodworking" you speak off? Is that for those who use the big table with the motor in their shop for something other than turning blank storage?
Leo Cuellar
B-E-A-Utiful.
Leo Cuellar
Nice work all the way around, John.
Alan Zenreich
Re: Nicely done
Alan Zenreich
Steve,
I have it on good authority that flatworkers produce shelves on which we place turnings.
Re: How did you grind the gouge?
Start with a triangular file. This helps you center the groove. Then switch to various round files. For bigger gouges I flatten the steel (hot of course) and then form it over a round bar. Then I go to the files and sandpaper wrapped around dowels or drill bits.
Re: Nice looking tools...
I use the tools in a cutting method, bevel rubbing, just like in wood. On rare occasions I use it scraping. It's all about rubbing the bevel and not forcing the cut. I can typically start sanding with 220 if I've done it successfully. Occasionally a metal won't cut clean and I have to scrape.
Very nice looking tools!!
Mike from St. Clair Shores
Steve Kubien
Re: Nicely done
Steve Kubien
Well, at least they're doing something worthwhile. :)
Here is a photo of the tip along with my other tools I use for ornament finials.
Re: Nicely done
Steve I have one of those powered tables. I use it to make photos of my work.
Very nice work-as usual!
Don Orr
Katherine Kowalski
Katherine Kowalski
Those are some seriously beautiful tools, John.
Katherine
Mike Brazeau
Thanks a bunch John.
