Re: Grex airbrush compressor.
Cindy Drozda
David would like to respond to the question/comments about the Grex compressor
AC1810-A:
As with all things compromise is an issue. I have been using the Grex
compressor and full line of Grex airbrushes for 4 years. I have also used
Iwata extensively and find little difference between the qualities of the
two brands. The Grex products are a better value.
The issue about pulsation is a factor with a tankless compressor if you are
operating at pressures close to maximum capacity. For most woodworking
projects, especially fine detailed work, this is not an issue with the Grex.
I recommend spraying at 15-25 psi. At this pressure the maximum output is
not approached and little or no pulsation is occurring that will affect the
performance of a 0.3 mm nozzle airbrush. Spraying at these pressures
requires finely ground pigmented acrylic paints or dyes.
I have been spraying with my Grex compressor a minimum of 4 days each week
for the last 4 years and the compressor is still strong. Yes, it is a
mechanical device and will eventually wear, but so will compressors that use
oil as a lubricant. All manufacturers are not equal. I believe Grex produces
a compressor that is good quality, is very quiet, light weight and
affordable. David Nittmann
