Re: Sanding with air?
Donna Banfield
Jorge, the need for a biiiiggg honkin' compressor is a necessity. But here is something that I haven't read in the preceding posts -- and what follows is only my experience, and therefore just my own personal opinion about air sanders. So read it, and decide yourself what works best.
I have two Random Orbital Air (ROA); the Sioux that Craft Supplies used to sell about 6-8 years ago, and the Grex, that they sell now. These sanders work best with the higher grits, i.e., 220 and up. I'ved used them with lower grits, but don't see any measurable difference when comparing them with a corded electric drill.
They will not shorten your sanding time because if you're using the ROA sander, you don't use your lathe to spin the bowl simultaneously. I'm sure there is a scientific, physics, mathematical (which is why I can't explain it) reason for what happens, but this it what does: as the sanding disc is spinning randomly, and the bowl is also spinning, you will begin to see a 'vortex' like pattern appear, and it gets bigger the closer you get to the bottom of your bowl. The way I avoid that is to move the bowl SLOWLY by hand, and use the entire pad (not just an outer edge) and go back and forth. This will take more time than if you could also run the lathe simultaneously.
Not all sandpaper works well with ROA. A while back I was using the Industrial Abrasives 1 meter by 1 yard sheets, and cutting my own discs. They were adequate with the corded drills, but whenever I tried to use them with a ROA sander, the disc would stall and stop. The Indasa sheets of grit (didn't matter the size/number) were too 'aggressive'. I was very frustrated; saw a few of Vince Welch's discs he sent as a sample, slapped them on the ROA, and they worked like a breeze. I now use Vince's sandpaper for all my hook and loop sanding needs.
Some bowl shapes don't work well with ROA sanders. If you have a very deep, steep curve/wall, the sander will stall. Even with the very flexible, soft inner pads.
Above, I said I use them for higher grits, but they take longer, so about now you're probably wondering why bother, right? I've found, and again, this is just my opinion, your (and hundreds of others mileage may vary) the finish I get from using the ROA sanders is superior to the same grit/finish using corded drills. For example, a 400 grit ROA sanded finish 'feels' and with some woods, looks like a 600 or 800 grit surface.
So if you're looking to shave time, this won't. If you're looking to spend a bunch of money, this is one way to do it :-) If you're looking to improve the overall quality and feel of the final finished surface, this might do it for you as well.
Good luck!
