The Bradford Pear that came down in my yard was so wet the bark will not stay on at all. It will almost fly off at high rpm's. consequently I just peel it off. The ends of this piece were chain sawn so I carved them to resemble the natural edge. Then I painted the edge a dark hunter black green and then sponge painted about 4 different colors of green with one of copper. The copper was a good touch. It adds depth.
Very nice John. I like what you did on the edge. How did you dry this piece? I am always worried about fruitwoods cracking etc., unless i let them dry over time.
I have had few problems with any wood when turned less than 3/8" thick. They warp of course. Bradford pear is one of those woods that you can leave the pith in without to many problems. I simply turned this to shape and let it dry. Then I mounted it on my vacuum chuck and returned the foot area so that it would be flat. On bowls that don't warp as much I just flatten the bottom with some sandpaper attached to my workbench.
I used the vacuum chuck to hold it and sand it and get rid of the wrinkle around the crotch figure.
