Re: Epoxy Help Please
Chuck Engstrom
A couple of more tidbits:
Use syringes (ask your vet for a pair) to measure small quantities and you will save a lot of waste. I can reliably mix 0.6 cc resin with 0.3 cc hardener for products that mix 2:1 like System 3 Clear Coat. West System loves for you to use a whole squirt from their generous pumps when only a little dab is needed, and their mix is (I think) 5:2 to make the issue even more challenging.
Recently I coated an end-grain goblet with epoxy and later put it in a sort of warm place to speed up the chemical process. What I got was a bunch of bubbles when air in the pores expanded in the warmth and came to the surface. By the time I noticed this my coating had gotten pretty well along in hardening and I had to sand the bubbles off later. Perhaps if you warm the workpiece before coating, you'll get the reverse effect of drawing the epoxy into the grain as the wood cools before the epoxy hardens.
One of our members likes stuff by www.rotdoctor.com, which he tells me is very thin and very slow to cure so that it will sink in deeply in rotted/spalted wood with full effect, which might take as long as a week. Not cheap at all but if that's what you need it may be worth knowing about.
Best to all--
Chuck
