Sharpening a skew - Poll ???
Doc Green
I know how I sharpen my skew, but I'm curious as to how others do it. So, how do you sharpen your skew? I assume everyone hones, so you can skip that part unless you have a special technique.
1. Use a jig to position it against a grinder.
2. Adjust the guide on the grinder to the correct angle, then free hand.
3. Use a flat, belt-sander type of sharpening device with a jig.
4. Free hand on either a grinder or a belt-sander system.
Please comment if you have a special technique that doesn't fit any of these four methods, and feel free to share any good advice or tips you may have.
Thanks in advance. ~Doc
Re: Sharpening a skew - Poll ???
Alan Zenreich
Alan Zenreich
Freehand on a JoolTool
Greg Haugen
Doc,
#2, if I'm understand "guide" as platform.
I use straight grinds and radius grinds on my skews. There's advantages to both. I do not like the skew jigs. I set the platform to the angle of the bevel and "dress" the bevel (either straight or radius) (bevel length is also approximately 1 1/2 times the thickness of the skew-give or take, if it's a rectangle profile skew). After the grinder I'll hone with a fine diamond hone (600 grit). I'll go back to the grind when my honing lines are getting too thick. I also like an angle of 70 degrees from toe to heel, if it's straight or radius.
That's it in a nut shell.
Doc I use a custom jig I built to help align the skew. I milled a slot in my Oneway tool rest and then made a jig with an aluminum guide that rides in the slot. The top part of the jig has a V block with the angles I want for that skew. I have one for my oval skew and one for my flat skew.
I grind several of my other skews by hand because I have special angles and they don't get sharpened very often on the grinder, mostly just diamond honed.
for final sharpening I use hand held diamond hones from medium to ultra fine.
I've heard some people say the hollow grind makes a weaker edge but the hollow grind starts 1/16 to 1/4" behind the actual edge so I think there is plenty of thickness here. The actual edge is the weak point. The hollow grind makes it easier to hold the diamond hones flat on the edge which gives it more accuracy.
As you can see I have a few skews and use them for all sorts of cuts and have tried lots of different angles and grinds.
Carole Valentine
Jennifer Indy.USA
#2, which I'm guessing means adjust the platform and then free hand.
Jen
Steven Antonucci
Ditto
steven antonucci
Keith Tompkins
keith tompkins
My conventional skews are ground on a platen freehand. My own version has a bevel ground on only one side with a convex grind. I will be demo'ing it at St. Paul in the Packard booth, if anyone wants to check it out, or just say "Hi".
Dale Miner
You mean they have to be sharpened?? They seem to open the paint cans fine with the grind that came on them.
Seriously, Adjust the platform on the grinder and free hand. Some straight, some with a Lacer type grind. I don't have an oval skew, but have sharpened them for other people the same way.
Ditto
Richard Jones
Richard Allen
4 polish on abrasive rubber wheel
Richard Allen
Free hand on the grinder (no jig or platform). Then polish on an abrasive rubber wheel (edge trailing wheel rotation)
#3 and #2 depending
Mike Foster
Sharpen on a platten
Jorge Casta�eda
then to a hard Arkansas oil stone when I need the ultimate.
Lan Brady
Doc,
I sharpen on a flat stone.
Leather strop for about a year, and then resharpen.
Lan
Don Orr
I freehand all my skews. The curved edge/radiused edge skews I grind very infrequently on the side of the wheel. Before you get all worked up about using the side of the wheel, there is very little pressure against the wheel for very brief periods. I find I can see what is going on much better. I do not hollow grind any of my skews-they are either very slightly convex (most of them) or flat (oval x-section). I only grind when absolutley necessary, which is almost never. Mostly I simply use a diamond hone (Lacer 600 grit). It takes a few seconds to bring up the edge without going back to the grinder all the time. I also often strop on leather (rough side up) charged with white compound-mostly for the flat beveled skews.
Katherine Kowalski
Never assume...
Katherine Kowalski
I free-hand grind my skew on the grinder. If needed, I use a platform to set an initial angle if I am grinding from factory.
I grind a straight edge with a convex bevel... and I never hone. (Takes too much time & with one or two cuts, the burr is off anyway.) I also like to use the burr for negative-rake scraping.
Katherine
Terry Scott
I use a woodcut true grind or a wolverine
I never Hone as I seem to always round over the edge
I want a bur as I use my Skew for many things its not designed for like negative rake scraping and a planing cut on the out side of bowls (you thought I was going to say to open cans of paint )
Oh and I dont grind I just zip zip and back to the lathe so use very little steel .
Another thing I want is a concave slope
Leo Cuellar
Leo Cuellar
robo hippy
What is a skew???
Well, I do use them some times. Mostly platform grind and turn. No honing. I do have one that is used mostly as a negative rake scraper which has an Eli Avesera grind (convex, not concave) and hone on a 320 diamond stone. Puts up a nice burr for adjusting the shoulders of a threaded box.
I do know a local turner who is self taught and is a master spindle turner. She sharpens on a 60 grit 6 inch grinder. Never hones.
robo hippy
I'm wierd...
I use my water stones. A skew is the same as a chisel or plane blade. It takes me only a minute or two.
David Walser
I'm not sure where using a Tormek fits in the poll, but I use Tormek's jig and water wheel for all but my 1/4" skew. (The blade of the 1/4" skew is too short to fit in the jig. I sharpen the 1/4" skew freehand on Tormek's water wheel. Freehanding the 1/4" skew is so easy it's giving me courage to try the same with my other skews, but using the jig is so quick I'm not sure I will ever give it up. ) With all of them I hone on Tormek's leather wheel and in-between Tormek sessions I maintain the skew's edge with a diamond hone.
Ron McKinley
No jig, no toolrest, just freehand on the belt sander and I seldom hone......Ron
charlie belden
Peter Pipe introduced me to using PSA sanding disks stuck on a disk of 3/4" MDF, mounted on a face plate to sharpen skews freehand. If you want to put a curve in the cutting edge you merely rotatate the tool around its long axis - spending more time in that sweep at the bottom and a bit less at the long point. Putting that curve on the cutting edge, pulling back that nasty long point a bit opened up the use of a skew for me. Now skews have become my favorite instead of most feared turning tool.
I used to use the SIDE of my Tormek wheel in place of Peter's MDF sanding disk arrangement but have switched over to using the WorkSharp 3000.
For wider skews, I use the Wolverine flat table and swing the skew to get my curved cutting edge.
Though I bought the Tormek "Skew Jig", I never got around to using it since it doesn't do curves.
