Chainsaw Envy *LINK*
I found this last night while waiting for my late evening assignment. I want one.
http://www.youtube.com/watch?v=kYhh_i5wc2o&feature=related
I want to see the lathe...
Chuck Jones - West TN
... that he uses to rough out this bowl.
Re: Chainsaw Envy
Dick Hines
Just by the sound of the saw It seems to me he needs a little biger motor or a small bar.
Re: Chainsaw Envy
Dale Jablonski
no eye protection. Interesting comment below on the blue stain as indication of metal in the wood.
Definitely metal in the log
steven antonucci
The sawyer by me won't even touch a log if he sees the staining. He keeps a box of all of the stuff he's found in logs. I'd love to see the mill that they slab that 1/2 log on...
S
I'd say probably, but not definitely...
With my bandsaw mill I only have a $20 band at stake, so if it's a nice log I gamble on whether or not there is metal. Sometimes I will see a large stain and never find the metal, and sometimes I see no stain and hit metal. Like most things about wood, there is always an exception.
Around here the big mills that have large (usually circular) saws won't buy a log unless they know the logger and he assures them the logs did not come from a yard. That's why I get so many nice black walnut trees for free
If I can remember it I will take a picture of a slab in my shed that is full of sliced sections of 30-06 slugs. Some deer hunter had used the tree to sight in his/her rifle. It hardly even dulled the band.
A sawyer at a relatively small yard told me recently that a large nail cost him about two hours down time and over $100 in new teeth. He said the replacement parts for a ruined blade for his mill would be $2700. He doesn't like to gamble.
Question on lead slugs: They don't stain?
steven antonucci
As far as I've ever seen, it's usually an iron that produces the stain in the video. The further in it is, the longer it's been in the tree, since the tree grows over it. I am not sure how long it takes to degrade the metal, but I have to assume that it is possible for something to be completely consumed given enough time. I don't think the stain ever disappears (since I can't even bleach the dang things out!)
In your sawing, have you come across lead slug that stained? Copper (perhaps a ground wire)? I wouldn't expect anything to happen to a saw blade if you hit them, since they are both soft metals.
Just wondering
S
Re: Question on lead slugs: They don't stain?
I can't remember whether the lead slugs caused a stain, but I doubt it. It is my assumption (purely a guess) that the stain comes from the reaction of ferrous metal and the tannin in the wood. Similar to the ebonizing slop woodturners make from steel wool and vinegar-- suggestion which I dutifully followed before I realized it wasn't worth the effort when boot polish and india ink does it better.
Your dissolved metal theory may very well explain the stain-no-metal occurrences. It is also possible that the metal is small and positioned such that the saw doesn't hit it. (My apologies to the woodworker downstream who hit it with the planer or saw)
A good metal detector helps
steven antonucci
I had some walnut that had nails and enough staining that a blind man could have said "there is metal in that log". (agree on tanin stains)
Sadly, I used my bandsaw blade as the metal detector. Instead of a beep, it makes a series of ticks before it stops cutting, usually followed by a loud series of blue stained words...
S
Jorge Casta�eda
Lead oxide is white, so It is not the stain in that picture. Copper can be very hard and even soft it would mess the saw. I did work in an electrical wire factory and after every stretch, it has to be annealed to be able to go through the next die, and it is just a few thou's.
I have turned some bowls and found lead shot in them. Don't recall any staining.
I have a bowl I turned from a walnut tree somebody had nailed up a piece of copper ground wire as a clothes line. As I recall there was not much staining from the copper, but plenty form the staples and nails.
Re: Chainsaw Envy
Bob Macgregor
That cost me a lot of time. I ended up watching a bunch of clever Stihl ads. I especially liked the kitten in the tree ad and the "chainsaw massacre" horror film takeoff (though the leaf blower one was a hoot, too!).
BOB
