What's it called and where do I get one
Carol Reed, Strawberry, AZ
Today I wanted to put a live chuck on the tail stock.
Do they make such an adapter?
Re: What's it called and where do I get one
Barb Siddiqui
Re: What's it called and where do I get one *LINK*
Barb Siddiqui
Do you mean a 'live center' for the tailstock?
Craft Supplies USA
Mike Brazeau
Oneway make a series of adapters that are normally used to temporarily mount a bowl in a chuck on their live center when reversing for vacuum mounting. Scroll down the page at the link. Complete list is at the bottom of the page. There was a reference recently in the American Woodturner for spindle turning with a chuck at each end. Supposed to dampen out vibration.
Oneway live center
Yes, but I want to thread a chuck on it. I have a Jet live center. Craft Supplies has chuck adapter for the Oneway live center.
Wonder if it will work.
Saw that, Mike. Wonder if it will fit a Jet live center?
Scott Hurley in N VA
It should. The Jet live center is a clone of the Oneway - same threads.
Scott
Super! I'll call'em tomorrow! Thanks, Scott.
I have a live center for the tailstock. Now I want a live center that I can thread a chuck unto.
I found this at Craft Supplies: http://www.woodturnerscatalog.com/store/Lathe_Accessories___Revolving_Centers___Oneway_Revolving_Center_Chuck_Adapter___1way_revolv_adapter?Args=
But it is for a Oneway live center. I have a Jet live center. Don't know if the thread will match.
Jim Sebring
Penn State has a live Jacobs-type tailstock chuck on a MT2 taper. Their part number is LDC2MT. I drilled and tapped mine for a 1/4 x 20 drawbolt. That way I can pull a little tension on a very thin piece (like a finial) to minimize flex. The drawbolt ensures the thing stays in the tailstock taper.
Barbara Gill
I use mine all the time when I use my vacuum chuck. I also use it when I make boxes. You can go to Oneway's website and see them. I really like the ones they carry because they are made from steel.
Carol The oneway adaptor does fit the Jet and Powermatic live center. I have it and the solid tailstock adaptor from Bestwoodtools. For reverse chucking bowls using my vacuum chuck I prefer the Bestwoodtools non live center. The reason is simply it's faster. To use the Oneway adaptor you have to find the locking pin thingy that comes with the live center. This holds it still while you screw the adaptor on. Then if you get the chuck on just tiny bit too tight you have to find that same pin to lock things up so you can remove the chuck.
The advantage of the Oneway adaptor is that once in a while rotating the bowl helps seat it better although usually you can just rotate the vacuum chuck and do the same thing.
I've thought about using the chuck to pull on thin spindles for stability. It doesn't work. When you start the lathe the centrifugal force of trying to start the chuck rips the spindle apart. Now if they were both geared together that would be a different horse and I'm going to build one of those gadgets one day.
Concur with Mike
Jorge Casta�eda
I use the One Way tail stock adapter for their live center all the time, it is a very small price for a great convenience. Not only for reverse mounting for vacuum, sometime while shaping the outside I cannot find a comfortable place to arrive to the desired form, so I reverse mount to have a comfortable way to arrive to the shape.
This should be a standard item provided with any lathe...
3/4" x 10 tpi Oneway thread
Don Evans
Carol
Just so you know for purposes of double checking things now and future the thread size on the Oneway live center is 3/4 x 10 tpi. I don't know what the Jet is but others here have said it is the same. I have the Oneway adapter that you are talking about and it is high quality which is very important for this, you want accuracy, saves time and aggravation when alignment is in question.
I personally like the Oneway and the little thingy that John mentions is no problem for me to keep up with, I have a shelf dedicated for those things, chuck keys and many other things of this nature, there is a hole drilled in it for every one of these things I have and I just use it then drop it back in it's spot. Any time (rarely happens) that I see an empty spot I find it and put it back.
Don
Re: 3/4" x 10 tpi Oneway thread
Thanks, guys.
I will check the thread size (thanks, Don) on my Jet live center. I think I did once and then bought a tap to match.
I plan to order the Oneway adapter. Along with a couple of other goodies. Funny how that works. LOL!
Barbara Gill
John, to use the adapter you do not have to find the pin. I use an awl but an Allen wrench will also work.
Russel
A small finish nail will work. I have used masking tape to hold the nail in while turning a threaded block to turn special jam chucks on the head stoick end of my lathe . Then back to the tailstock and out with the pin and you have a live jam chuck that fits your turning perfect.
Barbara Your right, anything you can stick in the hole. I was just making a point that you need something to lock it in place.
I use a cotter pin when I want to make a custom adaptor. I put the live center in the headstock, put a cotter pin in the aligned holes, screw on the blank that will be the new adaptor, or tip and then turn it to shape.
Check before you order!
Bob Edwards
I think this is what you are looking for:
ONE PIECE HEADSTOCK & TAILSTOCK CHUCK REVERSING ADAPTER
2MT-XXXRegular price: $79.95Sale price: $64.95
This is a #2 Morse Taper and you choose the thread size of your chuck insert.
You can find them here: http://www.bestwoodtools.com/
Information.
Bob Edwards
For those of you who aren't aware or are not an old codger like me, Oneway changed the design of their live center a few years back. One of the improvements was to increase the dia. and thread size. The older version, like mine is smaller. Depending on how far back you go the Jet and Oneway may not be the same. I found this out trying to buy points for my old Oneway. They two are a different size.
Jon Garcia
the oneway live center looks just like the powermatic live center, does anyone know if the oneway live center adapter fits the powermatic 3520b live center...?
Yes!
Jorge Casta�eda
That is what I have Jon, The Powermatic live center is an identical copy of the One way.
Re: Yes!
Jon Garcia
nice one, thanks Jorge...!
Ace Foster
I ran across a reference a while ago to a glassblower's lathe that had both the head and tailstock powered. That might be just what you need.
Good one, Ace. Then I could do a twisted turning!
Dick Hines
Dick Hines
The live centers on the older PM's were a knock off of the Oneway. Not sure about the Jets.
Those adapters are good to have. I use mine when i am reversing a bowl onto my vacuum chuck. Runs true every time.
