Safety cage
Safety cage
Keith Tompkins
Safety cage
keith tompkins
The big powermatic lathes come with a safety shield...I've never seen one installed on the lathe; they all seem to be discarded. Anybody use theirs? Could there be a market for similar devices?
Re: Safety cage
Re: Safety cage
woodspinner-HARRY ROBINETTE
I have a Vega 2600 and I do use the cage till I'm all roughed out and less likely to throw any chunks of wood off. Then it's just me and my face shield.
Re: Safety cage
Re: Safety cage
The larger Jet lathes also come with the safety cage. I have mine somewhere. I have used the mount that holds the safety cage - but not the safety cage.
Re: Safety cage
Re: Safety cage
Keith I've thought about using mine as a barbecue grill for turkeys. I have a perfectly good never used one somewhere in the shop if anyone wants it.
Re: Safety cage
Ric Taylor
Re: Safety cage
Ric Taylor
They make a great magazine rack to put beside a recliner.
Ric
Re: Safety cage
Re: Safety cage
Dick Wilson
Keith, I have used a Jet 1642 that had a cage on it. I tried it and found it even more anti-vision than a face shield. I moved it out of the way. IMHO if you can't see what and where you are cutting it can lead to problems. I think turning at a slower speed and using a face shield eliminates a lot of the danger factor. The cage IMHO is a liability CYA for the manufacturer.
Re: Safety cage
Re: Safety cage
Philip Duffy
Mine is installed and it holds all kinds of nice little handy things but it has never been put down over a workpiece. Yet, once in my life, when I really needed the protection, it was up instead of down. Dumb on me! Phil
Re: Safety cage
Don Leydens
Re: Safety cage
Don Leydens
Pretty much the same thing here. I have a PM and took the cage off the first day. I use the holders for other things but still haven't found a use for the cage which has been taking up space in my garage. It really does block the view of the piece you're working on. A face sheild has worked fine instead.
Re: Safety cage
Rob Wallace
Re: Safety cage
Rob Wallace
Hi Keith!
The "cage" from my Jet 1642-2 still has the original bubble wrap on it from when I bought the lathe years ago, and it's stored somewhere up in the attic.... I took one look at it on the floor model, and decided it was wasted steel. I do enjoy using the bracket to support my Moffatt light, and I often use the 3/4" mounting hole to support a holder for my dust collection hood. The bracket is more useful than the cage, at least to me.
See you in St. Paul!
Rob
Re: Safety cage
Re: Safety cage
Jorge Casta�eda
I use the base of it and another one on the tail stock to have a model of a baluster to look at, when not doing spindle work, the one on the tail stock goes to storage and I use the one on the head stock for a lamp.
Re: Safety cage
Re: Safety cage
R Henrickson
I used the cage on a Jet 1642 during two beginner turning classes at Woodcraft several years ago. It was very efficient at catching shavings and blocking my view of what I was trying to do, and got in the way of handling the tool. The store no longer mounts the cages on its in-store lathes. When I bought a 1642, I hung the cage from the shop ceiling, where catches dust and the occasional high-flying shaving. Jet also supplies a metal 'basket' to mount under the lathe bed, to hold tools I suppose. I installed it initially, but it was really efficient at catching shavings, so it got removed and hangs with the cage.
Re: Safety cage
Re: Safety cage
dick strauss
Keith,
It makes a nice holding tray for the underside of an open stand Delta 14" BS or any other open stand tools of the right size. I put the basket shaped shield inside the leg assembly with the radiused side down. It fits nicely and allows the sawdust from the BS to flow right through it! You may need to wrap or wire or two around to firmly mount it to the leg assembly but that's it.
Re: Safety cage
Re: Safety cage
Charlie Anderson
Mine never made it from the garage where the lathe was delivered to the shop. In fact, it's still in the factory packaging.
Re: Safety cage
Dick Hines
Re: Safety cage
Dick Hines
Mine went to the dump on the first trip after I got the lathe home.
Re: Safety cage
Re: Safety cage
Richard Jones
Mine is hung on a wall by a couple of hooks and is currently holding a few rough outs................
But..................faceshield and safety glasses, 99% of the time, and that number may go up............
Be safe.
Rich
Re: Safety cage
Re: Safety cage
Rich Egan
I screwed mine to the underside of a workbench. It holds a number of short wood scraps very nicely.
Re: Safety cage
Brad Vietje
Never Used Mine   :~)
Brad Vietje
Re: Safety cage
Re: Safety cage
Keith Inscho
I leave mine in the up position. I taped a piece of plastic to it to keep the wall behind the lathe from getting soaked when I turn green. ;)
Re: Safety cage
Re: Safety cage
ihmserv
mine hangs on the wall near the lathe,
some times use it for a tool holder.
mostly a dust collector.
IAN
Re: Safety cage
Re: Safety cage
david holley
i use mine half the time i turn
Re: Safety cage
Keith Tompkins
Re: Safety cage
keith tompkins
Interesting responses...I think only one turner uses the shield. Yet, many in a previous post stated they wear a face shield. In the event of a major disaster, the face shield is nearly useless, while the machine shield would almost certainly prevent injury or possibly save your life. Do we have a false sense of security because of the face shield? What design change would make the machine shield acceptable? Would you wear something resembling a catcher's mask with built-in eye protection that provided REAL LIFE benefits, yet didn't interfere with your vision?
Re: Safety cage
Re: Safety cage
woodspinner-Harry Robinette
Well Dave H.
I guess we're the odd guys sense we use ours at least a little. Because mine is on my Vega Bowl lathe
it doesn't seam to bother me when I turn, I only use it on the big bowls over 20" and just till their ruffed
out and running true cause even at slow speeds them 100 lb piece hurt when they or a piece of them comes off.
Re: Safety cage
Katherine Kowalski
Re: Safety cage
Katherine Kowalski
Being a bit of a trekker, I thought about this very thing last night:
I think we should call up Cmdr. LaForge and ask him if he could create a limited-diameter forcefield, one tuned to the materials used. The tool steel and handle, (as well as the operator's flesh) could pass through, yet the project wood could not. In the event of the disaster, this "bubble" of energy would catch the debris before it hit the operator or anything else in the room.
Of course, practically speaking, it would be quite a difficult thing to design any contraption to hold the piece and allow sufficient access/view to the form.
I think the best option we have is education... teaching good turning techniques, grain direction and how to cut it, wood types and their individual characteristics, safety, etc.
(But if anyone has a spare force field generator lying around, e-mail me! :) )
Katherine
Re: Safety cage
Seriously? - LaForge?
Toney Robertson
The original was the best, Scotty would be the guy to ask!!!
Aye captain.
Re: Safety cage
Re: Are you seroius?
Steve Criscenzo
You cannot mail a force field. It will not fit in the envelope and it will leak out of a box.
Steve
