Multi-Off-Axis Elm Hollow Form
George Guadiane
I did a demo on this at Totally Turning. At the end, I cut this piece off of the tenon (wish I hadn't done that), to show how I would do it.
The outside is all done between centers, mostly with scrapers. No special chucks or other fancy gear.
There are 3 outer axes in addition to the center. Ths was created by aligning the axws A/B - B/C - C/A in a series of re-orientations so that I could make the sides close to equal looking.
Eventually, I'll do a series of them, but they need to be hand sanded and wood selection is important, because if you get a lot of tear out, you'll never get a decent finish.
I sanded each side then applied some water based poly and sanded with the next finer grit. This is sanded to 400 with one coat after that.
4 1/2 inches high.
Re: Multi-Off-Axis Elm Hollow Form
David Walser
Very cool. Thanks for sharing.
Ron McKinley
I really like that shape.......Ron
Forgot to point that out!
George Guadiane
Thank you!
When these pieces are spinning on the lathe, from the center axis and I look at the "ghost" form, I was trying to make a pleasing shape.
Its more difficult to see when its not spinning.
Chuck Jones - West TN
I like that
It prompted me to try one this morning. I had some trouble sorting out which ghost I was looking at so I didn't get all three sides as equal as I would like, but it was still fun and not bad for a first try. I've been deferring multi-axis attempts for a while now. Thanks for the motivation.
Re: I like that
George Guadiane
Here are some pictures of the blanks and how I set them up so that I can get more even sides:
I use the colors so that I don't get confused about which axis goes with which on the other end... Match the color and you're good to go.
The cut in areas are so that I can match the depth on all three sides. Cut in far enough and they disappear. I usually cut a second deeper set for refining the form.
Don Orr
This piece is even nicer in person ! And seeing the demo makes it look easy-but it's not. It takes great care and patience to get them to come out this nice.
Well done George.
Leo Cuellar
Very Nice...
Leo Cuellar
George! I really like the way you dealt with neck on this piece. Gives it a nice twist :D
Thank You To Everyone
George Guadiane
