This California Olive was cut last weekend and end-grain Sealer applied the same day. When I looked at my woodpile the next day, I thought I was looking at a bloody crime scene! But the red that you see is a reaction of the "Woodcraft" brand of anchorseal on the olive. The red coloring is within the wax coating and not within the wood. Accordingly, it is no problem at all, but I wonder if you have had any similar experience. (The two pieces I placed on top were not coated for color reference.)
I'd contact Woodcraft and see if they can help with an explanation. I'd be interested to know what's going on. I'll try some Anchorseal on some olive and see what happens. Maybe we have a new dyestain ingredient in the offing here.
Thanks for posting. Tough about that nice pile of olive.
Just was looking at some Olive I packed back to Alaska from Arizona -- split it down the pith on the band saw and used Anchor Seal brand on the pieces -- and they are as red on the ends and where I slopped the anchor seal as yours are.
Surprised me -- but I have no experience with green olive so did not know it was unusual.
I used a plane iron (what was handy) and the color on the face grain is only about 1/32nd inch deep and not much deeper on the end grain. Color seems to be in the wax.
Note that UC Coatings is supplying their new Anchorseal 2 (i.e. not the Classic Anchorseal) in various colors. It may not look very dark when applied, but as the emulsion reduces through evaporation, the color will deepen.
I suppose you can now color-code your wood blanks if you want with emulsion sealer, using a fairly broad range of available colors:
Never seen that before but I don't have a lot of experience with sealers for green wood.
The strangest thing I have had happen is when I am finishing verawood with my thinned poly mix and after applying the finish and wiping off the excess with paper towels the toweling turns blue.... I was concerned the first time I saw this happen because I was afraid the wood was going to change color radically.
If you like it too bad the red is going to go away....
I don't know for sure if you guys are pulling each others leg or what. The last two five gallon buckets of AnchorSeal I have bought at my sawmill have the red dye added. It's because enough of us complained that it wasn't easy to tell which logs we had sealed. In any case I like the story about the olive reacting to it.
