Tippy tops
Tippy tops
Tippy tops
Coyne
A friend and I have been trying to make 'tippy tops'. We have watched utubes, read articles on line, asked friends, and said bad words. We have made them larger, smaller, hollowed deeper, longer and shorter stems, and they all spin well on their bottoms, but we haven't gotten one to flip over. is there a secret of success? Or are we doomed to eternal failure and depression?
Help.
Coyne
Re: Tippy tops
Re: Tippy tops
Bob Edwards
This is just one of many links you will find by doing a Google of "tippe top"
http://www2.hawaii.edu/~nikolaj/tippe_top_manual.pdf
This may be more information than you were looking for!!
Re: Tippy tops
Re: Tippy tops
Fred Holder
I did an article on the tippe top in the March-April 2005 issue of my magazine. Here is a section of the text from that article.
One of the main features of the top is that it is spherical and when set on its
spherical end the stem points straight up. I took information from the patent drawing and went to the shop. I used a 1" sphere as the basic structure of the top. I picked an endgrain point and drilled a 1/8" hole about 7/8" deep. I turned away the first 1/8" of the sphere diameter on the top of the sphere and then hollowed the sphere straight down for about 5/8". I then glued in a 1/8" diameter dowel that was near 1" long so that I had a bit of stem sticking out of the surface of the sphere. It worked. Probably a little refining needs to be done but this is the general way in which it works.
Re: Tippy tops
Chuck Jones - West TN
If there is a special club for tippy top...
...challenged people I want to join. I feel your pain. After about 6-8 I have not had one turn over yet. At the TAW symposium in 2010 Mark St. Leger tried to explain to me what I was doing wrong. Didn't help. Still can't do it.
You can find a copy of his handout at http://www.markstleger.com/. Follow link to "Articles and Handouts"
Re: Tippy tops
Re: Tippy tops
Ken DeMarco
I thought it was just me! I made a dozen of these a couple of years ago without a problem after seeing a pic of one. I tried to make some for christmas this year and they were ALL dismal failures, and I dont have a clue as to why.
Ken DeMarco
Re: Tippy tops
Re: Tippy tops
Terry Scott
Mate Ive sent you an email with the contact for Eugen Schlaak in Niagra falls hes the master of tippy tops makes hundreds of them and they all flip over
Iam sure hed only be to happy to help
Re: Tippy tops
Betty Scarpino
Re: Tippy tops
Betty Scarpino
Coyne,
I've made a few tippy tops, years ago. It's important to have the bottom section as close to spherical as possible (no point or hollow at the bottom, either). The other key is the length of the stem. If the stem is too short, the top will not tip over. The same is true if the length of the stem is too long. (And I believe that the stems need to be straight at the top, no flair.) For the ones you've already made where the stem is too long, try shortening the stem slightly. For the ones where the stem is too short, give them to the most annoying guys you know and see if they can get the tops to tip over ..... (of course telling them first that YOU can get them to tip over, illustrating that fact with one that really does work).
Re: Tippy tops
Re: Tippy tops
Bob Edwards
In addition to all the good advice your getting and all the Google search results
Mark St. Leger has a handout with measurements. Not that the measurements are critical but the proportions are. Have a look here:
Re: Tippy tops
Re: Tippy tops
Coyne
Thank you for the information and references, In spite of all your help, my tops do not yet tippy.
The most encouraging info was that some of the rest of you have the same trouble, and I am not unique as a tippy top klutz.
I shall continue to try, and if I find a magic 'open sesame', I will share it with all.
Coyne
