Good to have another ww visit....
roger lance
my shop. I'm not a turner but I have a lathe....a Delta 46-541....which was their standard duty VS 12" gap bed lathe that was made for about 40 years and was in thousands of schools and shops. Every once in awhile, I'll leave the flat stuff alone and play with this lathe...but it is VERY noisey (loud)...uncomfortably so...and I've tried all manner of things to cut down this noise with some small success (the lathe passes the nickel test from start-up at 360rpm to 3000 and back down again....so vibration isn't bad). The other day, I had a turner friend, Matt Hutchinson, come over to show me how to put fingernail grinds on a couple of my tools and we talked about my lathe and I mentioned the noise issue. So we turned it on...he listened for about 10 seconds and said, "the motor mount - have you got any wedges ?"....I handed him some small wood wedges that I keep...he pushed them under the motor mount plate inside the cabinet...and low and behold things quieted down remarkable....not completely....but its now pleasant to be around this lathe now when its running. I have many other Delta tools...all of the same vintage as this lathe....and there has never been an issue with a motor mount on any of them....so I wasn't even looking at that as a possible source of this clatter. Thanks Matt !!...its good to have other woodworkers visit your shop from time to time....you can get a new insight that really helps.
