(Message Deleted by Poster)
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Re: (Message Deleted by Poster)
Katherine Kowalski
Re: Wood River Diamond Wheel
Katherine Kowalski
Hi Jim,
After Cindy's recommendation, I've been using one for about a year now, and I really like it.
There is an article about grinding wheels in the latest AW, however, I find that my own experience has been quite different than some of the conclusions reached.
From a production standpoint, (I sharpen my tools FREQUENTLY), the diamond wheel has been an enormous boon! It is very delicate on the steel, (which is great for saving steel, especially on all those powdered metal tools I have!); the tools last much longer than grinding with a 120 grit Norton 3X.
The diamond wheel puts a super fine edge, and a mirror finish, on the bevel. The wheel is rated at 120 grit, but I think it must be something more like 220 or so.
I have one installed on the left side of my grinder, and a Norton 3x 46 grit on the right. The 46 grit is to grind tools, creating the initial shape, and I use the diamond to sharpen. The diamond is VERY slow if you want to change the shape of your tools.
Of course, in connection with this, you must set up your sharpening equipment accurately... either jig or platform... or you will spend much time getting to the cutting edge. (Jig misalignment with a standard wheel is bad enough... with a diamond the grinding time is much longer). To reduce errors, I have a platform set permanently at my angle of choice (40'), and swap it out if need be.
One tip for you -- the diamond wheel performs better when you shorten the bevel significantly: less surface to grind = less time spent.
I find the diamond wheel especially invaluable for sharpening Cindy's signature "pointy" spindle gouge, which requires a VERY light touch.
Any more questions, please ask away!
Katherine
Thank You Katherine for your response and feed back,
We did spend a good amount of time talking about her pointy gouge, a 1/8" point radius and ground at 40 deg. Watching her use the light touch making her cuts was very impressive. I have an gouge that has the same potential in my set and I may try to create the same shape on mine, free hand on a platen.
I was also take by her well developed set of negative rake scrapers and her use of them in many steps in her process. A great day for all.
I will post some pictures later.
Take care,
Jim
Steven Antonucci
Diamonds are the wave of the future
steven antonucci
I wonder if they can be used to sharpen carbide?
I use DMT finger sized paddles when I travel and I am a huge fan of diamonds for sharpening. I think that my Tormek is getting close to needing another wheel (#3) and I will closely look at a diamond wheel for it when the time comes.
S
Re: Diamonds are the wave of the future
Hi Steve,
Sharpen carbide?? ;)
I use several diamond plates along with my Shapton's for sharpening my plane irons so a wheel sounds right, and clean and cooler for steel, nice.
I switched to ceramic for honing my skews awhile ago, I found the DMT cards didn't last long.
Take care,
Jim
I've looked at the diamond wheels but don't see the advantage vs the money. I sharpen very frequently. My 8" wheel still has a lot of life left and I put it on there about 5 years ago. With my jig set up I remove so little metal that my tools last a very long time and so does the wheel. I'm using a 100 grit white wheel I believe it was J hardness but would have to look to be sure. I'm not a production turner but during the good weather I turn several days a week and most weekends. I go through a lot of wood. Before I set up my grinding jigs using the 3 point method of positioning the V Arm on my Oneway I ground away a fair amount of steel. Now I remove almost nothing. The diamond wheel might be better but it's quite expensive.
Jim Sebring
CBN wheels look like the way to go - if you have deep pockets. The article in the new "American Woodturner" is pretty informative. D-way seems to be the only U.S. supplier of these new wheels. Better be ready to pony up about $200 for an 8 incher. That's more than Tormek gets for their black stone. I need to hit the Lotto ;-)
Chuck Jones - West TN
... and my experience is pretty much right on with Katherine. Only other comment is "I miss my sparks!". I've always watched for the sparks coming over the edge as an indicator that I'm one target. Forget that. Almost no sparks with the diamond wheel.
I'm certainly not a production turner. I probably go through about as much wood, but I get very little production. :( I have read on earlier threads that some folks think the diamond coating is wearing off. I'm not aware of that. Like Katherine said, it's not intended for, or much good for, reshaping a tool. That might be why some are wearing the coating off.
Me too !
Doc Green
I've gotta chime in since I've been quite vocal during chat singing my praises for the Wood River Diamond wheel. I've had mine a couple of years now and it seems good as new. Perhaps the "grit" has smoothed out a little, but it still does the job.
Shined a small flashlight on my wheel the other day, and I could see the tiny diamonds sticking out from the surface. They sparkled, even! Then touched the wheel (under power) with a crape sanding disk cleaning stick, and it cleaned the wheel nicely.
I'm convinced that most people apply too much pressure to the tool. As has been said already, a very light touch is best - No sparks, and No heat!
And, it will sharpen a small carbide cutter. Your mileage may vary. ~Doc
Jim I just measured my wheel. It is 7 3/8". I've used 5/8" in 5 years. The Wheel cost about $30 from either Enco or MSC I forget which. It is 1" wide white wheel, J hardness, 100 grit. I true it up regularly and sharpen a lot. I have a 3/4" wide 80 grit on the other side. It came with the lathe. I use that one for rough shaping and sharpening my scrapers and Stewart Batty grind. Although I'd love to try the fancier wheels because I'm a tool nut and love to experiment, I just can't justify the price.
Here is a photo of jig I use to set my Oneway system. I set it up for the bowl gouge and then put a V block made of wood in the V arm to raise the Wolverine jig up for sharpening my detail and spindle gouges. All use the same settings on the Wolverine jig. This method allows me to set the V arm exactly the same every time even if the wheel is different size. That allows me to remove the minimum amount of steel for each sharpening.
I've had the Thompson V 1/2" bowl gouge for at least 2 years if not more and I've only ground off 1". I compared it to the new tool I just got which is how I no this. I was amazed because as I said, I sharpen a lot and each time think, man I'm shortening this tool. Well apparently not.
Re: I've had one for about a year...(long)
Donna Banfield
now. I just scanned the American Woodturner article Friday night, and my experience with it falls somewhere between that article and Katherine's.
I free-hand sharpen all my bowl gouges using the Hannes Michelsen grind. I still use a Oneway jig for my spindle and detail gouges. I have two grinders, one has Norton 3X wheels, a 46 grit and 80 grit. The other grinder has a Norton 3X 80 grit and the Wood River Diamond Wheel. The Wood River Wheel allows me to put a very fine edge on any of my tools holding it free-hand. In fact, I don't have anything underneath that wheel, such as a Wolverine base. I simply have a piece of wood that extends about 2" or so beyond the grinder platform, which gives me a place to rest my left had while holding the tools for sharpening the bowl gouges. I have a lot of students and club members in my shop and have personally seen the 'HEAVY' hand that some of them use to bear down when sharpening. I could see that aluminum core getting dished very quickly right in the center when using a jig. If that happened, there would be no way to 'true' that aluminum core. So, unless you can free-hand sharpen, that wheel is useless to you in my shop.
I agree that it was a bit pricey, and the jury's still out for me as to whether it will do something that my Norton Wheels don't already do. I'm not saying it isn't a nice wheel, but I seem to be able to get a very fine edge from my Norton Wheels when I'm putting that micro bevel on my gouges (again, remember, all sharpening I do on this wheel is free-hand). When the time comes to replace it, I may go with another Norton Wheel. But that's still a few years down the road, and by then next new 'Woodturning Craze/Fad' will hit the market :D
Fortunately we have the American Woodturner, Woodturning Design and these forums to give us a lot of information about these new toys...er tools, and if and when we make our decisions, they can at least be informed decisions.
Ricc havens
John - I like your plywood gauge set up jig. Do you have a template or drawing for cutting one that i could get?
Thanks
Ricc
Steven Antonucci
DMT paddles are $7
steven antonucci
I don't think I've worn one out yet, but the new one I just bought cuts much faster than the 3 year old one. I have a ceramic (Spyderco) bench stone, but it's too cumbersome for honing a skew.
I need everyone to write to DMT and have them make the 8000G paddle for $7! For now, they aren't producing it...:(
S
1 micron paste
Jorge Casta�eda
Steve,
In the flat side I remember reading about 1 micron paste to load a leather strop.
Surgical results!
Extreme care...
Fred Holder
I've been using Diamond Grinding wheels from Andre Martel in Canada for almost three years now on my Woodcraft Slow Speed Grinder. I have an 80 grid diamond on the left side for roughing and a 360 grit wheel on the right side for final sharpening. These wheels are balanced and run for a long time after the grinder is turned off. I realize that I'm not a production turner who sharpens every few minutes, but I find that the edge obtained from the 360 grit wheel is sharp and seems to stay sharp longer than tools that were ground on my old white wheels. So far I haven't experienced any of the things that the guy writing the AAW article mentions. The Diamond Grinding Wheels are not cheap, but I would hate to have to go back to regular grinding wheels.
It's not that hard. I simply cut a shape roughly like you see but longer. I layed the plywood in the V groove and next to the wheel. Then I traced the wheel. I removed a little wood near the wheel mark so only two places touch the wheel. Then I actually touched the wheel with the grinder on which ground away any uneveness and made it fit perfectly. I have them made for each tool that requires a different setting. I also made some that fit on the flat platform so I can set it to repeat angles.
Here is a shot of the riser block I use to sharpen my detail gouge using the Bowl gouge setting for the V arm
Steven Antonucci
Have it, strop...
steven antonucci
I need to make finger strops... the DMT paddles are a very ergonomic shape for attending to imperfect edges. My strops are all too big and unwieldy.
S
