Sweet gum
Sweet gum
Sweet gum
Don at Central Illinois
I have a friend, fellow turner that asked me how sweet gum turned. I can't help because I've never turned any. If you can give me your thoughts, I will pass them on to her. I may even trade this knowledge for some of the sweet gum. Thanks in advance.
Re: Sweet gum
Dick Hines
Re: Sweet gum
Dick Hines
I turn it and like it. It may or may not have any good figure though.
It's full of water if fresh cut.
Re: Sweet gum
Re: Sweet gum - I like it
Steve in Durham NC
A friend gave me a load of it last year. Logs up to 20" I made several bowls and a couple of platters. The grain was not real exciting but I put some stain on a few and it helped it pop a bit.
It is very easy to turn, sand and finish. It is also the wettest wood I have ever turned green. I was soaked when finished and had to cover everything in the line of fire to keep it dry. Because of the high moisture it moves a bit so give yourself enough wall thickness. I had no trouble with checking however just dry them slow. (I kept the bowls wrapped for several months.)
Re: Sweet gum
Emmett Manley, Lakeland, TN
One of my favorite woods. Here are a couple of paragraphs I wrote for our club newsletter.
For the woodturner, sweet gum is a delight to turn, and with a most pleasant aroma. The wood can be fairly bland but, more often, displays streaks of varying hues. In some cases, this wood is confused with walnut, especially if just the heartwood is used. To add to the confusion, the heartwood is sometimes called red gum -- or, in some parts of America, the sweet gum tree is referred to as red gum.
Sweet gum is one of those woods which is prone to warping, which can range from minor to very significant -- bowls made from sweet gum often assume an attractive (to me, at least) oval shape. Like other �hard to split� woods, sweet gum is not prone to splitting, although splitting may occur with improper storage.
For the turner of sweet gum, either expect the wood to warp so finish your item and accept the beauty of oval turnings; or, rough turn your bowl or other item and come back in a few months and shape your final product. Because of the warping tendency of this wood, it is not a good choice for lidded containers or other items which must fit with a close tolerance.
Re: Sweet gum
Chuck Jones - West TN
Here's a bowl from sweet gum
This wood came from a fairly large sweet gum tree with a lot heart wood (red gum). This one is about 14-15". Couple coats of Maloof Poly/oil and buffed. I'm not having as much trouble with the moisture and warping, probably because the tree had been dead for a while before I took it down.
I have sawed quite a bit of sweet gum and if I park the dozer on top of the stack it doesn't warp quite as bad. Seriously, it is pretty wood if you can get it dried properly.
Re: Sweet gum
Re: Sweet gum
Thanks all. Actually, I did get a small log of the sweet gum and told her to get on WC as I knew we would have good answers. I met her at the visitation of Kieth Adams of Decatur, IL. He was one of the original members of the AAW, who passed away last Saturday. Lot of wood turners at the visitation as he taught a lot of us how to turn and turn correctly and safely. He will be missed.
