Have a question? Ask Woody!
"Time Escapes Everyone"
Dick Wilson
This is the piece I was talking about recently on the Wednesday night chat room. Apparently, I wasn't expressing the idea very well. Walla, here it is. I was watching TV one evening and someone made the comment "Time Escapes Everyone". For some reason that stuck in my head and several days later the saying and the turning popped into my head. This is the first piece that the name of the piece came first and then the turning. The hour glass is Water Oak, found from Georgia around the coast into Texas. This particular piece came from Texas. If you remember I was cussing here about blowing up a turning. On the first one I turned, the center was too small and when I was hollowing the second half using my three wheel steady it twisted apart . This is a successful turning. It is one piece of wood, double hollowed to 1/4" wall thickness. It had some moisture in it and I was hoping that it would check big time. It didn't.....my luck. The stand is made of Walnut. It was really nice to get back to some flat board work. Play sand used to represent lost time. All comments and critique welcome. Comments and critique welcome as always.
Re: "Time Escapes Everyone"
Randy Gleckler
That is a really really neat piece. I think you did the saying well with your work. Nice job.
Fred Bearman
Moments ago, as I was looking at this picture, my wife came into the room where I am - and as she said "Isn't that cool!," I've got to agree. Very nice!
at first I read "made the sand out of walnut"...
Thad Parker
...but it's still quite impressive.
Nicely done.
Chuck Jones - West TN
Beautiful and quite a technical feat
I really like it. Especially the form of the two bulbs. Great wood. Water oak!! Never thought I'd see a piece of water oak look that good. Cleaning up after one of the hurricanes I saw water actually running out of a log we had cut. You could have caught it in a cup.
My apologies for asking a dumb question about such a nice display, but how did you stabilize the sand?
Glue and CA glue
Dick Wilson
charlie belden
Message pieces can be really interesting to do. A great example of a "Seed", in this case a phrase, handing you a piece. All you have to do is make it ; )
Interesting message - interesting result.
Great idea and execution
Mike Foster
Nice piece Dick. If you turned it really thin, the walls would be translucent and you could see the sand inside. :D I can definitely understand the problems you encountered turning it as I've done a few pieces recently with the same type of torque issues.
Aage Rendalen
We mortals wonder how you did it
Aage Rendalen
Very nicely done. But we morals wonder how you did it. A cage chuck?
Re: We mortals wonder how you did it
Dick Wilson
Aage, I knew what I wanted to do but I had to ponder for a while on how I was going to go about doing it. I finally came up with a process that is very simple. I use a Jamison hollowing system and I have a three wheel steady halo. I started out turning the hourglass form, leaving a fair amount of wood in the center ( the first one I did twisted apart). I turned a tenon on the tailstock end for my chuck. Flipped it end for end between center. Chucked it and captured it in the halo. I turned a small flat spot on the end, bored a hole to start hollowing and hollowed out the first end. I then turned a jam chuck, if you will, that just fit in the opening and CA glued it in the opening. I flipped it end for end again, put it in my chuck between centers and employed the halo again. Making sure everything was secure I bored and hollowed the other half :D :D :D. I got rid of the jam chuck and between centers I turned the middle of the hourglass. Pretty simple process. It sounds more complicated than it was.
