A55 Smoothing Plane
Question on Osage Orange color Change
This is a question about a piece of flat work, but I am asking here on the Turning board because I suspect more of you have turned it than flat work people have worked with it. I built a highchair for my cousin and her little boy. As many boys are, he was rough on the chair, sliding it across a brick floor and turning it over. Turns out that Osage is as hard as WoodPeckers Lips but also brittle. I need to repair the chair. It cracked in several places and I am trying to decide whether to glue the cracks and make minimalist repairs or make replacement parts. I still have some of the wood from the same tree. The question is about the color. The wood was originally bright yellow, but over the years it has mellowed to the color of dark iced tea. Or maybe a good bourbon. So, is it safe to assume that if I make repairs and use the same wood, they will age and darken to match? (I think they will, but I have a turning or two that I went back to and worked on later and I don't think the color ever blended as well as I thought it would.)
Re: Question on Osage Orange color Change
Bob Strand
I've turned a good deal of Osage Orange and, as you've noticed, it always darkens. To say it would darken to the same color hue would be a stretch but it will darken. l
Help it along
Whenever I do repairs on cherry or another wood that darkens or changes color noticeably with age, I consider staining it to match the adjacent aged color. The worst that can happen is that it will get a little darker as the color in the wood itself oxidizes. If the repair attracts too much attention to wait a year or two, this is an easy out.
Barry I can't say for sure because I've never repaired an Osage Orange piece. I have however turned quite a bit of it and played with the color change. I think the color change is fairly rapid at first if placed in a place with a lot of UV light. So I'm guessing that if you do the repair and put it in a room where daylight will hit it the change to the new parts will go pretty quick and I don't think the old parts will change much. That's purely an educated guess. Older Osage doesn't seem to change color much once it's reached the Bourbon stage (you must drink better stuff than I do). New Osage will change to a tanish color in just a few days in direct sunlight, slower by north window light.
Dick Hines
Dick Hines
Barry, the piece you are repairing has a head start. The new osage may never catch up. Just a thought.
Sounds like a perfect opportunity to
Keith Newton----Little Rock, Arkansas
Make the replacement parts, then put them in a closed container with some ammonia to me. Half a day, may be all you need to catch up the oxidation.
Emmett Manley, Lakeland, TN
Just put osage orange in the sun and that bright yellow will go to dark brown in short order. If you discover any way to keep that from happening, you will make a lot of people very happy.
Chuck Jones - West TN
I've seen a 1937 model OO duck call...
... and what a beautiful object it is. It's about the color of a deep, rich black walnut. The friend who has it tricked me into saying it was black walnut. Then he showed me the markings. Also with more careful observation you can see the different grain patterns and chatoyance.
From my very limited experience with OO I basically agree with the others. It will have to have some help to catch up with the older wood. But having said that I doubt that after a couple years it would be very noticeable.
