What type, size and number of fire extinguishers do you have in your shop? We had a good chat session last night talking about fire extinguishers. This got me to thinking about what I have in my shop. I do have one, it's small and gets moved around from time to time. If I had to use it the fire would probably be beyond the capabilities of the extinguisher by the time I located it. As a result of the chat session I am going to buy at least one more and mount it to the wall so it is always in one place.
One other thing that came up is a fire extinguisher is more about getting you out rather than putting out the fire. It does not make you a firefighter so if you need it take care.
I have several in the shop. The best advice I got was to put the fire extinguisher by the exit door. If a fire starts you go to the door grab the extinguisher and then decide whether to go back in. My shop is a separate building. Obviously if the shop is part of your house the decision making changes.
It might be worth checking for a local company that services fire extinguishers. For some reason that I do not understand they sometimes have a good deal on extinguishers that they have removed from commercial/institutional locations that they have refilled and are perfectly good for a shop, etc. One of my club members son-in-law runs the local extinguisher service company and he just gave him about twenty of the 2' tall size; and he gave me two of them.
For combustibles, the kind of fire most likely encountered by us wood people, consider ALWAYS keeping a garden hose with an adjustable nozzle available that will cover the shop area. This is an endless supply of water . This is also approved by most fire departments in lieu of a class "A"extinguisher.
They sent a guy out to my place and he made the recommendation for type , size, and number of them. I carry extra insurance because of the shop. Too much stuff to cover on a normal house policy. If you call a company that provides such things, it's going to cost you big time. Those guys are not the least bit bashful about their prices. When I had a commercial shop, I had to pay up on an annual basis for them to inspect. Seems like they found a little something wrong with them each year. Not a suprise since I had to have them inspected to conform to fire inspectors and insurance inspectors. The supply guy could charge what he wanted.
Any fire department (volunteer or professional/full time) worth its salt will be happy to provide advice on the type and rating of extinguisher needed, and most would probably be willing to do a site visit for specifics.
After getting trained in fire safety to manage my lab at the University (and seeing some videos of impressively 'nasty' fire situations), there's no way I would NOT have an extinguisher in the shop. Even though I have few noxious chemicals in my shop relative to those in my lab, wood dust and shavings can burn faster than some solvent fires. And I've already done the experiment with oil-soaked rags and self combustion - it works as they say, and can happen if you are not careful.
Currently I have 10 pound 'B' rated extinguisher near my finishing area, a 20 pound ABC by the shop door, and a 20 pound ABC on the wall near the dust collector. University regs. at Iowa State require that EVERY lab must have an extinguisher within 3 feet of the main exit to the room, and at locations for which a potential fire is at an increased risk. I follow that same advice at home, and probably should add one near my grinder too.
Your conditions and needs may vary.....
Good luck and congratulations on keeping "just in case" as part of your thought process...
We actually had a woodworking club meeting where we invited fire department personnel to come and talk about workshop fire safety, extinguishers, their placement in work areas, combustability of dust, etc. It was a great meeting and it was one of those meetings where a HUGE number of questions were asked.....with everyone paying attention!! Try it - you'll like it! (We even recruited one of the three firefighters doing the presentation into our club that evening!)
Several years ago we had a propane fire on the deck due to a loose connection at the tank. The mess caused by the ABC extinguisher sent me off the next day to get two of the more expensive CO 2 extinguishers. The extra labor in cleaning up the powder from a minor job is not worth the extra expense of the CO 2.
I have four extinguishers in my home. They are all 3-A:40-B:C extinguishers. One is under the sink in the kitchen. One by the door between the garage and house. The other two are in my shop.
I have had two fires in my home in the last ten years. One in the fireplace which I put out with two extinguishers. One in my shop at the lathe when I tried the Jimmy Clewes method for raising the grain (alcohol and flame). That fire took three extinguishers because two of them were expired and didn't work.
Check your extinguishers at least once a year. Most come with an inspection tag. Use it. Nothing is scarier than having a fire and then finding that your extinguishers are dead because of age.
Learn to use an extinguisher properly. Aim at the BASE of the flame where the item is burning. Be prepared to get out fast. Your life and family are worth much more to save than a few tools, a car or your house.
Yes, the dust from these extinguishers is nasty. When I had the fireplace fire, the dust effectively ruined my TV. (That turned out to be a good thing because I used the event to justify my first flat screen HD TV :-)
