THE WOODRAT IS BACK!
drill hole
drill hole
drill hole
James Pittman
I would like to drill holes in hss planer blade.I am trying to make differant shape cutter for a home made turning tool. can someone help me. Thanks Jim
Re: drill hole
Steven Antonucci
my guess
steven antonucci
Never tried drilling a planer blade, but I am guessing that you'd want to mark the spot with a punch, set your drill on slow and put a drop of oil on the punch spot. If your hole is larger, then you might drill it in several passes and work up to the final size.
Steve
Re: drill hole
Re: drill hole
Scott Crumpton
Regular drill bits are also HSS so they're not going to be of much use. Your run of the mill concrete bits (tungsten carbide tipped) might work, but may not be able to take the heat. I know that the Bad Dog silicon carbide bits will do it. Basically, you spin the bit as fast as you can and press as hard as you can. Friction heats the metal softening it so that the bit can cut it. Usually HSS is cut/drilled using lasers or abrasives.
Re: drill hole
Re: drill hole
Fred Holder
Its been a long time since I drilled a planer blade or some sort of hardened HSS, but I always used a small tipped torch to heat the area to be drilled until it turned red to hopefully draw the temper. Otherwise your drills will probably just get hot and turn soft.
Re: drill hole
Re: drill hole
Stuart Johnson
Rather than drill a hole you might try using a disk grinder and grinding a slot for the screw.
Re: drill hole
Re: drill hole
Jim Pugh
Stuart, that's exactly what I was going to suggest. Use a cutoff wheel in a Dremel. Makes it easier to install/remove as well as you aren't likely to remove the screw completely and drop it in the chips.
Re: drill hole
Re: drill hole
woodspinner
I just cut the blade to the shape I wont around one of the holes thats already there.Just use a cutoff whell and shape it how you wont.
Re: drill hole
Re: drill hole
James I haven't read all the other posts yet but what I do is cut slots. You can cut slots in the HSS with either a cutoff blade in an angle grinder or with patience you can use the cutoff blades in a Dremel.
You can drill a hole in HSS but it takes a very expensive drill bit. I'll have to look them up but I think the bits are made by Aruu or something like that. They actually abrade their way through. You run the drill at high speed and apply lots of pressure. When it gets red hot it will drill right through.
Re: drill hole
Re: drill hole
I forgot to mention. Cutting slots allows you to remove the bit for sharpening without removing (and losing) the screw. I tried spot annealing with a torch. It sort of works but I still ruined a regular bit. Then I bought one of the bits designed for this. I think it was about $20 or so for one bit. It worked. The slot is so much easier and more useful.
Re: drill hole
Re: drill hole
Don Evans
This is another option but it depends on, where you are, a machine shops availability or a friend who welds and has a plasma cutter.
Go to friend or shop that will do it for you with a plasma cutter. They can not only cut the hole but also make the thing the shape you want with none of the slag problems associated with oxy cutting etc.
Don't lose sight of the fact that you can buy these cutters probably cheaper than you can do all this out of planer blades and then you can shape them on the grinder yourself if you want another profile.
Sometimes we get caught up in these type projects and spend more doing it than we saved by DIY route.
Then on other hand we learn more and end up with tool to use for futuer.
I've wanted a plasma cutter for long time but just cannot justify with my low volume use of it.
Let us know how it turns out, we may as well learn something on your dime!
Don
Re: drill hole
Re: drill hole
James Pittman
Thanks for all the help. I am going to try some of them. I have found when I have problem just post it and somebody will have the answer Thanks Jim
