Seeking advise on Norton 3X GWs....
roger lance
need some insight from experienced turners regarding choice of grinding wheels for sharpening turning tools, plane blades, chisels, etc....i've got a Delta 8" slow speed grinder and the stock wheels that came with it (am happy with the grinder...turned it off yesterday, the wheels are still spinning to a stop...but people say that the stock wheels are meant for sharpening the lawnmower blade and yard axe)...i've also got some Wolverine sharpening jigs and am wondering about upgrading to the Norton 3X grinding wheels...blue wheels....in 46 and 80 grit combination (or 46 & 120 grit if that is recommended)...so what say you ??....good, bad, or ugly idea ??....or some other product ?? Thanks all.
Re: Seeking advise on Norton 3X GWs....
Bill Jacksonville, NC
That is wheel combination currently using, bought on sale from Hartville Tool. Had to change out center plastic telescoping bushing on the 80-grit wheel. I also buy Norton X wheels from sharpeningsupplies.com. Prices little higher but better quality wheels and bushings.
Check for sales prices vary a lot.
Forgot to mention using "K" grade wheels, litle harder than "I' wheels.
Greg Haugen
Roger,
Those are good wheels. The Norton 3X wheels are becoming the standard by which other grinding wheels are being measured. As Bill mentioned, make sure you get the "k" hardness wheels. The "i" hardness wheels are little soft for turning tools (they'll cup and wear away easily and you'll have to dress the wheels more often-shortening their life). The Norton 3X wheels are a mixture of 30% ceramic SG abrasive (50% in the $100 SG wheels), as well as other abrasives. I'd recommend getting them from either Craft Supplies, Packard, or Sharpening Supplies (sharpeningsupplies.com). There are other suppliers that carry them but I'd strongly recommend you make sure you're buying "K" grade wheels. I've only seen 80 and 46 grits in the "k" hardness and that's a pretty good range of grits for sharpening turning tools. The wheels are cool grinding and fast cutting.
You'll be happy with them.
Bill Howatt
I have the Norton 3X K 80 grit wheel from Lee Valley. I'm very happy with it. It runs cool and but doesn't groove quickly like the softer white aluminum-oxide wheels.
Bill
Jerry Hall
All good advice. I like the 3x 80 grit K grade which works fine for shaping, but for touch up I much prefer the 120 grit, only available it seems in the I grade. But with a Wolverine jig properly set up it only takes 1 or 2 gentle swipes to refresh and edge, and it will be sharper and cut cleaner, especially on finish cuts. The softness hasn't been a problem for me on the 120 grit and my wheel has lasted me for a couple years at least with frequent use for sharpening, not for shaping the tool profile. I have only found the 120 at Hartville tool.
