A mans gotta do what a mans gotta do with the skew
Terry Scott
The start of another of my winged boxes
Time for the finish cuts and some detail
This is a bit of Pacific Yew about the size of a house brick 160 long x 80mm x 80mm .I dont worry about adding waste blocks as I havnt time to let the glue dry l.o.l
This is going to be a stunning piece of timber (if it doesnt end up as match sticks )
The bowl will be left natural and the wings carved with Yew leaves .Some one asked if when I made the Green Tea teapot if my intention was to have it end up how it did or did it just evolve
Like this piece (scary I know ) but I can visualize the finished work before I even put a chisel to the wood
Ill keep you posted on progress
Re: A mans gotta do what a mans gotta do with the skew
Terry Do you do the whole wing with the skew or just use it to finish the area you have in the photo. I use the toe of the skew to do things like the bottom of goblets and some pretty severe undercuts on finials but have not tried it on winged boxes.
I think my 1/2" thompson detail gouge would work better for me. It has a 35 degree bevel and is a thick tool. The narrow point seems to chatter less than other tools whenever I have cuts that just won't cut clean.
When you think in terms of the elements, you've probably done the cuts needed - an inside bowl cut on the undersides of the wings - just interrupted - twice. You're turning in air much of the time - but you've probably done some of that on a bowl with voids or inclusions. The other interruption of course is the "cup" in the middle - but you've probably done that if you begin hollowing a bowl while still between centers. The bottom of the cup is the same as cutting the bottom of a small bowl - and only gets a little tricky as you approach the underside of the wings. And for the cup - you're not turning any air.
Cutting the two wings where they join is a bit tricky - but mainly because of the knuckle busting potential, not the cuts themselves.
Though initially counter intuitive, high rpms cuts down on the TIME you're turning air - so less or no bouncing in and out of air. The noise the piece makes is a bit intimidating - but it's just noise.
What clenches my jaws is that Terry does these pieces with a skew. I use a skew a lot so the tool isn't scary to me. And even though Terry has shown shots of how he uses the skew on pieces like this - I've not worked up the courage - or confidence - to try what he does.
If you start small - a 2"x2"x4" the intimidation factor goes way down - since the propeller noise is much less.
The turning is not that hard. The turning it well - that's another story. And Terry's got the turning well part down really goooooood.
It's the sanding that's the really fun part ; )
Come on you guys! Put the stock on the lathe and crank it up to 3,000 rpm. Make it sound like an airplane prop. Put some excitement in your life. ROFL.
Terry, We have a skew demo by a professional spindle turner at our meeting tomorrow night -- I'll make sure he sees this! ;-) Can't wait to see your final product, Gary
I start turning the underside of the wings right from the start with a 35 degree gouge then start working the cut and grain first wing then bowl side an inch in I then revert to a spindle gouge as the 35degree bevel soon is unable to be rubbed .All the time I am consecrating on making a fare curve on bowl and wing Then the skew is used on the bowl
for the last 1inch to tidy up the definition between bowl and wing .I have a spindle gouge that is sharpened like a spear way way back so I can then shear scrape a finish that will need little sanding
The skew is used to remove all the V Remember this is cross grain but if the bevel is always rubbing you will never have a catch .The same principles as cutting a pommel for a post
Ive made 100s of square winged vessels and have never had a dig in
Yes as Charlie says you need to turn less air so the speed is fare humming this is why I always have the tail stock up as support
You will see the tool rest is as close as I can get to the work this helps to make a better noise chop chop chop
Id strongly recommend to practice the skew get a 6 x 6 long grain post as long as your lathe will take and tun it dont to a goblet miniature goblet ,by the end you will feel confident and had the satisfaction of making shavings
I think I can use the skew fairly well but dont ask me to make 4 legs the same
I just noticed, did we either miss a pic in the step, or how do you then reverse it to hollow out the Box? As you've cut all the way down the the nub, didn't know if you chucked it in a vacuum chuck after, or already had hollowed out the box portion.
This is turned as normal a spigot is turned and the piece reversed and the inside finished
Then I remount by holding onto the rim of the bowl in this case 50mm jaws and reshape the under side .I call this back to front turning as I turn the inside and finish first then make a template (male ) and use to make a female of this allowing for the wall thickness
I do the lids the same way under side first
You have to be able to visualize the concave shape under neath or you will cock it up
Terry, you say �The skew is used to remove all the V Remember this is cross grain but if the bevel is always rubbing you will never have a catch.�
Are you referring to the V where the two wings meet? If so is this done after you complete the finishing cuts on the lower wing and outer bowl profile?
Thought I'd see what would be possible when using jamb chucks. This is my first attempt at a piece like this, so I'm still working out the process. I think the balance issues are somewhat mitigated by taking a little off one side, then taking some off the other & back again etc. Still saving up for a lathe with variable speed
What ever the sacrifice .You will never look back.Trust me you will say why didnt I do this years ago
As an example when i was turning a basic salad bowl id turn at one speed and sand at another
With Variable speed I find myself altering ting the speed 15 to 20 times.
If I am not getting a clean cut up goes the speed
If vibrating up goes the speed until I hit the sweat spot
My process( habit)is turn down the controller to zero turn on the lathe and gently turn up the speed Oh thats after I check everything has clearance .I always rotate the work before turning on .Amazing how this habit has become second nature.
I prefer a variable speed with a knob to turn .Useing a lathe like a dvr and having to hold finger on button and wait P...s me off .I can finish a cut in the time these things take to ramp up or slow down .The preset settings also get me wound up
Also having a variable speed or at least having the switch on a flexible lead with a magnet is better than reaching across the work all the time.
Especially since most of my work is out of balance and has items sticking out.Only takes one loss of concentration and Id cut my arm off
Can yo tell I love my Stubby l.o.l
Have you thought of adding a unit to your lathe Ive just added a variable speed to a 3000 Nova cost $830 Nz and I sold the old motor for $100 (maybe a cheaper option )
Terry, it will definitely happen this year. I will probably by an assembled unit and then make a new body to my own specs to support the head & tail stock. Back to work full time now, and we will be expanding at work so overtime will be coming shortly! Just spent $500 upgrading my tool box @ work & adding a few tools.
I'll put some more pictures up later today. My camera battery was dying so I couldn't take a picture of my "secret" weapon.
Gotta go reinstall my woodstove that I reworked the exit on to eliminate one bend in my pipes. Should help having to clean the pipes so often & improve the draw.
