Bench Grinder????
Bench Grinder????
Bench Grinder????
Jim Tusant
I currently have a Delta 8" variable speed grinder. I am using Norton SG wheels in 46 and 80 grit. The wheels have been balanced dressed; however, I still get a bit of vibration with this grinder. My question is -- Does anyone recommend a grinder that is smoother and quieter than the Delta?
Re: Bench Grinder????
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Have you tried installing One Way Balancers on the wheels? I put them on my grinder and also gave them as a gift to a long ago acquaintance, it made a difference in both cases.
Take care,
Jim
Baldor..... *LINK*
Dick Coers
it will sound like a swiss watch, but costs $512. Did you run yours without any wheels? If it still vibrates, you could probably take it to a motor shop and have the armature rebalanced for less than the the Baldor.
Baldor 8"
Jim Tusant
Jim, that is how I balanced the wheels. I am still getting a little vibration. I have read some not so good reviews on the grinder. I am interested in what the other turners recommend in place of this unit. Also, I use the Wolverine system with the grinder. This is a great setup except for the slight vibration. I could live with it but there has to be a better unit available.
Ah Good then.
Sorry I can't help you with the grinder, I have an 8" General Slow Speed 1750 rpm grinder
Re: Baldor.....
Jim Tusant
Dick, I didn't think about having the armature balanced. Some people are saying that they believe the problem with the unit is the way the wheels mount up on the spindle against a stamped, not machined, washer.
The Baldor grinder has got to be the Cadillac of them all but I prefer the 1725 rpm range. The unit you pointed out turned in the 3000+ rpm range.
Re: Baldor.....
Steve Worcester
( I like how it says it is air powered)
That one says it is 3600RPM (which it is) and the lower text says it is 1800 RPM, which it isn't.
Ideally, you want the 8100W or 8100WD, 1800RPM, and for some reason they are alot more expensive.
If someone knows a place to get a deal on one, or group buy, I would be interested.
Mike Stafford
Re: Baldor.....
Mike Stafford
I love my Baldor grinder. If everything in my shop was as well made as my grinder I would be a very happy man.
The only tool in my shop that is quieter than my lathe is my Baldor. I know that grinder will be running long after I have pushed up a lot daisies...
P.S. I have two Baldor buffers, a 6" and a longshaft 8". Both are as quiet as the grinder. I love buffing out my flatwork boxes with the buffers.
Re: Baldor.....
Bill Jacksonville, NC
Now the Baldor 8100W � hp 1800 RPM sounds like the bench grinder for you at only $900.00 MSRP.
No sure what brand 8� bench grinder stands head and shoulder above the rest. Reading reviews on consumer grade China made bench grinders on line will find problems with all them. Not sure price is a real guide to quality. You can find � hp 8� bench grinders selling for more than $100. No-name brand with � or 1 hp for less than $100. Once a firm believer an 8� bench grinder should have either � or 1 hp motor. Now not so sure that will get you a great bench grinder.
I have been looking at Dewalt DW785 8� HD for $109 from amazon.com. I do not care about VS or RPM�s.
You may be able to take wobble out of your wheels by putting cardboard washers same size as big metal wheel washers on each side of the wheel. Put your metal washer on, slide on cardboard washer, wheel, cardboard washer, metal washer hand tighten the grinder spindle nut. Some manufacturers call them wheel collars or flanges. Another cheap fix, if telescoping plastic wheel bushing loose glue them so do not slide around once mounted.
Fred
I have a Woodcraft Grinder Slow Speed grinder, which always had a bit of bounce to it until I installed Diamond wheels with metal frames. The grinder now runs smooth and for a long time after it is shut off. The diamond wheels are expensive, but I like the performance and the 360 grit wheel gives an excellent edge on my tools. I purchased mine from Andre Martel in Canada.
Mike Stafford
Re: Baldor..... *LINK*
Mike Stafford
You can do a lot better than $900 on a Baldor grinder.
They are still expensive at >$660 plus shipping but it should be the last grinder you ever need to buy.
Look at the linked source....
Baldor Grinders
robo hippy
I got a Baldor 5 plus years ago. It runs as smooth and quite as my American Beauty. I never even considered bolting it down it runs so smooth. Add to that my CBN wheels, NO VIBRATION.
robo hippy
Most of the 8" Chinese grinders, such....
JamieDonaldson
..as the ones that Woodcraft sells, do have a high percentage of wheel wobblers right out of the box. I have tuned up many of these by simply loosening the wheel nuts and flanges, then rotating the wheels an inch at a time and that usually will tune out the significant wobbles. The Woodcraft grinders have stamped metal flanges that are not nicely machined like my Baldors, but they offer great value for the market price when properly tuned.
Barry
I have the Delta "Boat Anchor" slow-speed grinder. 1725 rpm and 90 lbs. It's not bolted down, but does have some vibration. I true up the wheels with the Wolverine diamond jig and a short time later they need it again. I have replaced both wheels with a Camel 60-grit pink and a Camel 100 grit and still have a bit of vibration. I also have a Woodcraft $89 grinder with stock wheels. It has a bout the same amount of vibration. I can't afford a Baldor. I'd have to sell my lathe. Maybe some day I will try the Oneway wheel balancing setup.
Jim Tusant
I do the wheel balancing with Oneway and I still get some vibration. The vibration is not uncontrollable but more annoying. This may be the norm with mid-range grinders. At least without the tweaking Jamie mentioned in his post. It looks like the only way to go is Baldor if you want to have a smooth ride! Thanks for the help.
Wally Dickerman in Arizona
I guess I got lucky. I got an $89 grinder from Woodcraft. After a bit of fiddling it has no vibration at all. I did take a couple of them out of the box and try them at the store and picked the best one.
Wally
I know Baldors are good grinders. I've used them. However it's just hard to justify buying one at $300 + dollars when my $89 Woodcraft grinder does the job. Perhaps some day when I'm flush with money I'll step up but for now this one does all I need.
bill Crommett
Again I am blessed. Some thirty years ago I bought a "Buffalo" grinder at an itinerant tool sale. It is a two horse, 10 inch grinder made in Taiwan and has run as smooth as a hair dryer, and about as loud. I didn't know grinders were supposed to vibrate until I bought a Sears grinder a few years ago and outfitted it with the Wolverine balancer and it still wants to rattle the rest of the stuff off the bench.
Dale Bright
If my memory is good and most of the time it is not, just ask my wife, Doug Thompson uses Dayton grinders. They are priced somewhere between the the chinese imports and the Baldor and they seem to be pretty well built.
Woodcraft grinder
Dave Peebles Lyons, Ohio
Hi Wally,
I did the same, but the first one out of the box was a smooth runner. I was prepared to try every one, but it was just clean livin' I guess that made the first one good :)
Dave
Bill Blasic
Re: Woodcraft grinder
Bill Blasic
Well I guess I'm real lucky as I have both the Woodcraft grinder and the 100 lb Delta and they both run great. A pointed diamond dresser is a must to me for making sure they run true.
Bill
Diamond Dresser *LINK*
I finally broke down and bought one of these. It is really really sweet. Very solid and flattens the stone extremely well as well as making it run true.
http://www.geigerssolutions.com/trudress.html
I haven't chimed in...
Dave Belser
I assumed that people know this - it can be very difficult if not impossible to true (and improve the balance of) a wheel with one of those hand held Tee style dressers. They clean the wheel but it's very difficult to true it up. The tendency is for the dressing tool to bounce.
I switched to the Wolverine diamond point dresser (the one John linked to is also probably fine) and it was a huge improvement.
I suspect that most of the medium quality grinders (Woodcraft?) are fine if setup properly. The suggestion to run it with out the wheels is a very good one. With no mass, it should run smooth and quiet. If not take it back. Problems with hubs can most likely be machined away (trued) if really bad.
Rob Wallace
Re: Diamond Dresser
Rob Wallace
I've got one of Don Geiger's wheel dressers too, John. This dresser travels much more easily than the Oneway Wheel Dresser (which I also have) for truing grinding wheels while "on the road" doing demo's. I throw mine in the travelling toolbox when preparing to do an "away" demo.
Rob
Re: Diamond Dresser
Rich Egan
I did the same thing, John. I struggled for a long time with my Delta VS grinder. Different wheels, wheel balancing kit, different bushings - all made some improvement, but no real cure. There is no runout in the grinder shaft. The Geiger dresser made the wheels dead flat. Now my tools just sit on the wheel and hiss. No jingle jangle bouncy.
Rich
