OT Sealed Batteries
Barbara Gill
This might sound like a silly question. Are there vents in sealed 12 volt batteries. If they are sealed why would there be vents to allow water to escape when it cannot be replaced?
OT Sealed Batteries
Barbara Gill
Re: OT Sealed Batteries
Richard Allen
When a a lot of current is drawn from a battery the battery tends to get warm and that warmth can cause the fluid in the battery to give off gas. If there were no vents then the build up of gas could lead to an explosive failure.
The sealed batteries I have seen can be opened.
The writing on the top of the battery is a thin plastic strip. That thin plastic strip covers screw caps for each of the cells of the battery.
Dick Hines
I know there are batteries that are used in boats that can be turned upside down and will not leak. One way vent?
Barbara Gill
Thanks Richard. So then what is the difference between the older batteries which could have water added easily and these "sealed" batteries?
Illegal Question! Ten dollar penalty!
Chuck Jones - West TN
Consumers aren't supposed to know this stuff.
I've wondered the same thing for years, but never got around to seeking and answer. Hope you succeed.
The most common type of battery in....
JamieDonaldson
...automotive service is lead acid which has a liquid electrolyte. Some are claimed to be low or no maintenance, but do require venting to avoid gas buildup that can be explosive. They do actually require some maintenance of fluid levels, but the cell covers are not always obvious. I use Optima gel cell types in my older cars, and this design doesn't have a liquid component and can be installed in other than vertical positions without venting or potentially corrosive acid leakage.
Don at Central Illinois
The main difference I see is that the older batteries had easier access to add water. The newer version usually pop off and reveal three compartments where you can add water as needed.
Thanks Everyone.
Barbara Gill
I found the places where water can be added. They were right where Richard said they would be. The battery is new so I didn't peel the decal up except for a corner.
This is a deep cycle battery for my sawmill. Right now I am trying to find out if the battery is not good or possibly I have another problem.
Re: OT Sealed vs. Flodded "Wet Cell" Batteies
Brad Vietje
Barbara,
I use these batteries every day in the solar business. While there are differences between deep-cycle solar storage batteries and those used in starting engines, all the major properties are consistent.
Flooded cells use a liquid electrolyte, which can spill or leak. They are the heavy duty workhorses of the battery world, and offer * by far * the most bang for the buck.
However, they require maintenance, including not only topping up the fluid every now and then, but in applications where multiple batteries are strung together, should be occasionally juiced with an equalization charge to desulfate/clean the plates and bring them into balance with each other. When charging they can release highly explosive hydrogen gas, so they need to be vented in most applications, and can not be used in many commercial or medical settings where that would be problematic.
Sealed batteries are usually either "Gel" cells, in which the electrolyte is gelled, (like Jell-O), and can't leak all over when turned upside down or when the cases break open, or AGM, or "Absorbed Glass Mat) cells. AGM's and other "sealed" batteries are actually VRLA (valve-regulated lead acid) cells. They do have tiny vents, but these are to release pressure and hydrogen gas under extreme conditions, such as a prolonged over-charging. The electrolyte is gelled and has been absorbed into fiberglass mats that wet the plates inside. They don't leak, and in most cases do not need to be vented. This makes them ideal for boating and applications where they will be bounced all over, and might otherwise break and/or leak. They are also far less likely to be damaged by freezing.
Gel cells cost a LOT more per amp-hour of storage, but require no maintenance, and never get equalized. VRLA batteries are a middle ground -- more expensive (per Amp-hour) than flooded, but less than Gel cells, and require no routine maintenance except cleaning the contacts of corrosion. When Sealed batteries do get overcharged, the contact between the electrolyte and the plates can be upset, and the batteries can be ruined. In normal use, you never add fluid.
Hope that helps,
Brad Vietje
Newbury, VT
Re: Thanks Everyone.
Brad Vietje
Hi Barbara,
Looks like our messages crossed in cyberspace...
What is the make/model of the batteries? If there's liquid in there, you can check the specific gravity. If they are AGM batteries, you probably should contact the manufacturer before adding water.
Good luck,
Brad Vietje
Newbury, VT
Barbara Gill
Brad, how do you tell the difference. Are they identified on the outside in any way?
Barbara Gill
I will get the information from the battery tomorrow. Thank you Brad.
Re: OT Sealed vs. Flooded "Wet Cell" Batteies
Brad Vietje
Barbara,
Flooded: Batteries built with the expectation of adding water have obvious caps to facilitate watering. If there are smaller holes under the vinyl label, I would presume the manufacturer did not want you using those holes.
AGM, Gel and other "Sealed" batteries aren't so easy to distinguish, unless it is noted on the label. If you had to remove a label to see filling ports, they are probably VRLA's (usually AGM). Common batteries from Interstate, Power Battery, Full River, or other distributors would be easy to look up on-line. For example, DCS-105 from Interstate is a Deep Cycle Sealed battery with 105 Amp-hour capacity (at some rate of discharge). Batteries for starting engines are not rated or numbered that way, but there are charts available to look 'em up, and it should be possible to get the charging and maintenance recommendations. I'm far more familiar with true deep cycle batteries, but if I can help you figure out your battery issues, I'll be glad to help. I'll check in tomorrow, or send me info directly: greensun@fairpoint.net
Safe spinning,
Brad Vietje
Newbury, VT
Barbara Gill
This battery is only for operating the 12 volt motors. The motor that drives the blade and the alternator is 3 phase. I never realized batteries could get so involved.
Jesper, Denmark
No, gel in stead of fluid.
......and very expensive.
Brad- I've heard that battery packs.....
JamieDonaldson
...from cars are expected to be replaced when they have lost about 30% efficiency, and can be recycled for storage of electricity in applications like windmill generators. Do you have any info about this possible application?
Re: Brad- I've heard that battery packs.....
Brad Vietje
Hi Jamie,
I didn't see you question until this evening (Friday).
Short answer: I'm not certain. I don't know much about the life cycles of starting batteries, but the usual choice for storing DC power would be true deep-cycle batteries, which are fundamentally different designs.
Longer answer -- the differences: Starting batteries are designed to give a lot of "OOMPH" (a highly technical term!) all at once to start an engine -- like an explosive power. This is achieved by using lead plates with a lot of surface area exposed to the electrolyte, so there would be many very thin plates with ridges or perforations to increase the surface area. Deep cycle batteries have fewer, much thicker plates so they can give a more sustained power -- more of a slow, steady burn. As for storing power from windmills, if the power was stored for a sudden burst of power needed later, a car/truck battery might work very well. If power is stored to run a load for many hours between charges, starting batteries would be a poor choice.
And now, pure speculation: I'll be they are being used to store excess power that needs to be shed during high wind situations. When too much power is produced for the normal charging, excess power needs to be shed to protect equipment and batteries, and is often used to heat water or air -- a diversion load. Ideally, this diversion load would result in a useful outcome, instead of just being wasted to protect components. Charging a bank of batteries that are semi-retired might be a better choice than just running a heating element that heats air to shed excess amperage.
That's my best speculative guess, but I don't know for sure.
Safe spinning,
Brad Vietje
Newbury, VT
