Re: Chain
Barry,
Look carefully at your chain's cutters from the top and from the front.
The cutter must have a sharp "beak" viewed from the top. It must also have a sharp angle where the top and side of the cutter meet.
If, in top view you find that you don't have a sharp point on all of your cutters, the chain needs to be reground.
If, however, you have cutters with the outside corner rounded as in example 2 in the attached pdf, the chain has been ruined, usually by running one side against an embedded rock or anything harder than
the chain. In that case, the chain will never cut straight, so just pitch it.
If you've got sharp points on all the cutters, take a mic and carefully measure the length of the cutters on both sides. A chain, to run true, must be balanced, a few long or short cutters on either side will have you cutting curves in no time. Then check your depth gauge bars to make sure they are all even.
I got fed up with mower shops and the like blowing off sharpening chains. I bought a mid-priced chain grinder and do all my own and my friend's chains. I can also vary the grind depending on what kind of wood will be cut. I typically get 15-20 sharpenings on a chain as opposed to 4 or 5 from the shops, and my chains cut smoother and faster.
Lastly, I will dress the bar from time-to-time as mentioned. I don't, however, use a file; instead preferring the grinder. I use my Wolverine plate rest aligned dead center with the spindle, then just kiss one rail until the wear bur is gone, flip the bar end-for-end and do the other rail, then do the same on the other edge of the bar. Doing each rail this way negates any hollow grind from the round grind wheel. You can check your bar for true with a good try-square. Caution: Don't grind too close to your bar's nose and catch one of the sprocket teeth.
