I was unable to remove the ticking sound on my PM2035B. Here's what I did:
1. I removed the belt and turned the spindle. No ticking.
2. I turned the motor shaft and the ticking was back.
3. I removed the set screws on the motor shaft and turned it. Ticking unchanged.
4. I replaced the set screws and tightened them. Ticking unchanged.
At that point I gave up and turned two natural edge bowls. Annoying but it doesn't seem to affect the operation of the lathe. I suppose I'll get used to it.
Well I have been there took a very radical aproach (home made lathe) after all the possible reasons I just weld the pulley to the motor shaft by the hole on the front of the pulley and bye bye noise forever,If I want to change pulleys well just cut the first grove and a cuple of hits will make that piece fly out
...For those of us who are old enough to remember the John Cameron Swayze Timex commericials.
I've been living with the same problem on my Jet 1642 for a long time. I haven't approached the problem in a systematic way yet, which is what I'm going to have to do to ever nail it. It does not seem to affect the operation whatsoever, just affects my sanity which doesn't matter all that much. Every time I go to the shop to work on it I stumble over a piece of wood that I want to turn instead.
A year or two ago Jet Tech Support reckoned it was because I was tightening the drive belt too much. That actually did seem to make it go away for a while. I have at one time or another replaced both bearings and it didn't change a thing. Sometimes it will go away for a while, the come back with some variations.
When I get back from the TAW Symposium I think I'll make it a priority to find it. If I have any luck I will post the process and results. Good luck with yours.
Take a look at the end cap covering the fan that cools the motor. It might have something inside that is causing the ticking or the cap might have a dent and the plastic blades are hitting something causing the noise?
Ron, I looked but could not see any such device. Maybe I looked at the motor shaft instead of the spindle shaft, but anyhow, the problem does not come from the spindle shaft. When the belt is off, there is no ticking when I rotate the spindle shaft.
