Re: 2035B headstock ticking noise
Ron
I suspect you have a PM 3520B, correct?
I bought a new one about 2yrs ago, after a short period of time I had the same clicking you're talking about. Drove me crazy trying to find it. It only occurred under belt tension and finally isolated it to the motor.
Called PM and they sent someone out to look at it. He spent an hour or so going through all the same things I had and also concluded it was the motor. He came out again a week or so later and installed a brand new motor.
Guess what, after a short amount of time I started to have the same clicking. It's worse if I tension the belt harder, but even with the belt loose enough to slip some it would still click some. I've decided to live with it for the last year+. I untension the belt when I'm not using it, and mostly just let the motor weight tension the belt when I do use it - this seems to help but I still get the same clicking most of the time.
