Has anyone seem one of these?
GaryG in MD
I was watching some random TV "how to" show -- I have no idea what.
They showed sharpening a chain saw by attaching a cuff-like thing on the end of the bar and running the chain when pushing an extension on the end of the cuff into a solid surface for a few seconds. Sparks flew. I've never seen anything like this, have no idea what it's called, and can't find one with a quick Google. Anybody aware of them? Are they any good? What are they called? Who makes them? etc. ...Gary
Re: Has anyone seem one of these?
Rob Wallace
Oregon PowerSharp System *LINK*
Rob Wallace
Hi Gary!
A similar thread on this new tool was recently started on the AAW Forum. If you check out the link below, you'll see a post that has a link to Bailey's web site which shows an on-line video of the Oregon Power Sharp in use. In addition to the actual sharpening unit, the system also requires use of a proprietary bar and special Oregon brand chain for this system to work.
Perhaps this bar, chain, and sharpening system is a bit too new on the market to get enough good feedback from folks at this point? I'm not sure I'd be ready to replace the two bars and 8 chains I have for my Stihl 260 Pro, and I feel significantly invested in that aspect of the tool right now. I'm extremely happy with my chainsaw as it is.
Rob Wallace
Link to AAW Forum Thread on Oregon PowerSharp
Re: Oregon PowerSharp System
I'd like to see it in operation and use it. I thought my existing chains cut about a 1/4" of wood in the kerf, not 3/8" Am I miss-understanding this? If this cuts a 3/8" wide kerf, wouldn't it take a lot more power than a narrow chain? OTOH, if that chain were sharp, maybe not.
I did not think the Approx. $40 for the bar and sharpener was too bad, but $35 each for chains and a new stone seemed outrageous. OTOH, maybe I would not have to have so many spare chains if I could quickly sharpen hem in the field.
I use my chainsaw on a very erratic basis and somehow this appeals to me in that I would not have to take chains in and have them sharpened to have spares to be ready for next time that might be six months away.
I was about to say I will wait and see if this catches on, but I could buy the unit and a couple of spare chains and it might be a lifetime supply, or at least last until something better comes along. In any event I could go back to shat I have now.
Ps, I have an electric chainsaw....
that I probably use on a somewhat more regular basis than my gas saws and they don't recommend this for electrics. So then I am back to dealing with sharpening those chains. A mixed solution.
Lyle Jamieson
Re: Ps, I have an electric chainsaw....
Lyle Jamieson
There is only a couple of you that responded so far but you are typical to most turners. I use my chainsaw constantly. I dont use a band saw. I take the wood to the lathe with the chain saw as the only tool to get started. With that said I need to keep my chain sharp or it would be a big hassle. Now the key point I want to make. It is counter productive to have multiple chains and send the chains out to be sharpened. I only have one chain and I have sharpened it myself a zillion times over a 16-18 year period. It is easy, quick and free to sharpen it at home. The chain saw files are only a couple bucks at any hardware store. You can get a handful of sharpenings with one file, but dont let the file get dull. When the file stops cutting replace it. No jigs or fixtures are needed. Just take the file by hand and lay it in the curf/flute of the chain saw tooth. Push three or four lengths of the file past the edge and move on to the next tooth. It takes only a few minutes and you are back to work with a sharp chain. It's not rocket science. Worried about getting it right?? Get some help from someone in your club that can show you how simple it is.
One of the down sides to taking the chain out to a sharpening shop is they ruin it for home sharpening. The flute that the sharpening services leave behind is usually distorted cause they use a sharpening machine that has a sharpening wheel that wears over time. The chain comes back with different curf angles and sizes every time you get it sharpened.
Hand sharpening is cheaper, easy, faster, better...why send it out??
Chuck Jones - West TN
Easiest method of sharpening a saw is...
Go to any store that carries chainsaws and/or chainsaw parts. Buy this little tool about 9-10" long and a diameter of 5/32-7/32. It's called a file.
1. Hold it against the cutting part of the chain at an angle somewhere close to how the chain was originally filed.
2. Gently push it forward (repeat 3-4 times).
3. Move to next tooth.
4. Repeat above steps until done.
The hard part may be determining the diameter needed for your chain.
I'm as much a tool junkie as anyone, but I cannot believe the useless gadgets that have been marketed to do something so simple as sharpening a chain. :)
Lyle Jamieson
DITTO!!
Lyle Jamieson
Very worthwhile information
Sorry I didn't see this before I posted my "short hand" version.
Best method I've found so far but I'm open to idea *LINK*
I'm a fan of the Husquvarna saw sharpener. I still wonder if there is a better way. This method is quick, keeps my saw cutting in a straight line and is easy to use in the field.
http://www.youtube.com/watch?v=xXzoSEiu4R0
Re: Ask This Old House!
Charlie Anderson
I'm pretty sure Gary was watching 'Ask This Old House'.
I saw the episode a week or two ago, but I had recorded it with Tivo, so I'm not sure when it ran.
Ralph E Watts
Good advice from everyone, however, those of us from the Tim The Tool Man Taylor school need a motor.
I have an old Dremel and I buy round grinder bits that fit my saw. Fire up the Dremel, without a jig, and make a couple of strokes per tooth.
The good thing about this method is that if a tooth gets nicked, it is easy to grind out the nick.
The less than good thing is that if you are not careful, one side gets ground more than the other and your blade may run off to one side.
Other than that it is faster than a file and doesn't cost much.
Keith Tompkins
keith tompkins
Hey Lyle, I agree....I refuse to send my chains out. They come back ground down to nothing, usually blue from overheating. I always carry a spare bar and chain into the woods..If I get stuck, and I'm alone, I can switch bars, and continue working.
Lyle Jamieson
Lyle Jamieson
Sorry to disagree but the cutters for the rotary tools will wear unevenly and every tooth will have different size flutes. When you go back to sharpen the second time now the sharpening stone will not fit in the flute sharpened the last time. Therefore it is likely to get out of balance and probably not even get sharp sometimes. This would cause the saw to wander off line when one side of the chain is not sharp. I would challange you to a race and see who can sharpen faster. By hand there is no time needed to fiddle with jigs. The file is always the same diameter and the flutes are equil all the way around the chain. With no jigs the angles of the tooth will evolve to a slightly different angle then the manufacturer angles, but this has no effect on how it cuts. Like I said I have had the same chain for many, many years and it is still going strong.
Carole Valentine
I agree! Have tried all sorts of jigs and stuff, including "professional" sharpening. After none of that has the chain ever cut as well or as straight as when I do it myself, free hand, with a simple file!
Bill Howatt
I've used the cylindrical diamond burrs with a Dremel. Fast and sharpened the chain but you're right, after a couple of times it didn't want to cut straight.
Bill
Rob Wallace
Re: Has anyone seem one of these? *LINK*
Rob Wallace
Ralph -
I also use a Dremel tool (and occasionally files too) to touch-up my chains, and agree it is faster than filing. I have used both aluminum oxide grinding stones and diamond sharpening burrs, and find the diamond cutters last longer, and do not change diameter as Lyle suggests (which does happen with the AlOx stones). I get mine from Lee Valley; they come in 3 sizes, and last quite a long time if you don't allow them to load up. If desired, you can lubricate the diamond stone with a drop of bar & chain oil before grinding which reduces metal build-up on the diamond burr surface - these maintain their diameter in use. Every so often I take my chains that I have been sharpening "freehand" over a period of time for a "machine" sharpening which brings all teeth back to the same angle and depth, and the sharpened chain is very comparable to a new blade - a pretty cheap way to get the chain "re-calibrated" if necessary. I do not think it is normally needed to do machine sharpening each time the blade gets dull of you keep the blade "current" by touching-up the blade frequently but "lightly". Like any edge tool, every act of sharpening (machine or manual) removes metal, so it is unrealistic to think that blades or chains will last forever - obviously this is based on relative amounts of use, what kinds of wood are cut, etc. that determines the frequency of the need to sharpen.
I don't know about Lyle's sharpening service, but the place I take my chains to does an excellent job of sharpening and the results I get with my chains are nothing like Lyle describes in his post above. I don't believe that proper power sharpening ruins chain sharpness or geometry - perhaps he has to try another sharpening service?
Rob Wallace
Lee Valley Chainsaw Diamond Burrs
bill Crommett
Lyle must be one of those city guys that never cuts into dirty woodlot wood that has dust and gravel imbeded. Else a chain would never last a hundred hours. Another point: To sharpen a chain properly without altering the gullet, the stone should only be used against the cutting edge, not the gullet.
Re: Easiest method of sharpening a saw is...
Terry Scott
Chuck I think I have an easier way to sharpen chains
Let someone else do it
Yep I admit it I am hopeless at sharpening so I run 10 chains on each saw
When blunt take them down to Mr styl
The thing I have to learn to do is take 5 or 6 down and leave 4 sharp ones Not use all 10 then wonder what I am going to do to cut a bit of wood
Chop sharpener
Mike Foster
I guess I'm the only lazy one here. Lots of guys post that they take their chains to a sharpening service. I did the same for a long time when my chains seemed to pull to one side in a cut, or got really dull fast when I hit the ground with the saw running. I have to admit that this happens more frequently than it should. Mostly because I spend a lot of time clearing fields where they have overgrown, and I want the stump down low enough that I can use my bush hog on the tractor to mow them and keep saplings from retaking the fields. I realized what I spend at the saw shop, and the fact that I have to take them down then go pick them up.
So my solution was to buy an electric chain sharpener. These things are just as fast as sharpening by hand, but much more efficient and quick if you happen to have hit a rock and need to sharpen the chain way back to get to a clean part of the tooth to get a sharp point. Someone posted that the saw shop will reshape the tooth because of the shape of the stone. Having your own allows you to control this as you can dress the stone (just like we do for our lathe tools) and there are templates that I got with the Oregon sharpener that match the profile you want. I keep a bunch of chains as well. One sharp on the saw and one or two extra in the tractor. Dull ones wait by the sharpener. I sharpen them in batches and it really takes little time. Oh yeah, I think I paid about 1-200$ for it., but it has already paid for itself many times over.
JohnKyler
I have never seen one but would consider it when the time comes. I wont say no until I see how well or not it works. Never say never
Thanks All...
GaryG in MD
What a wealth of info we have here. WoodCentral is better than Google and Wiki and all that stuff put together.
Thanks for all the very insightful comments, links, info, etc. I think this thread pretty much covers the ground. ...Gary
