Raising the dead OT but not really
Jorge Casta�eda
1:11:11
Stand up Lazarus! Said JC...
No bible talk here, it is a tale of physics.
Last march a hurricane downed a colossal spruce tree not far from our house. The root ball, rather the root disk, was about 16' in diameter and just a hair off vertical, so a cut just in the right spot should make the root section stand up. After looking it a number of times, just long enough so my brain figured out the total mass of the root disk and an equivalent mass of the trunk so there was perfect balance, and then make "the" cut right there.
1:11:11 was the date. I wanted to post this yesterday but we lost our power in the snow storm. As the trunk in the spot where I needed to make the cut was way up, I had to cut several sections of 18", dictated by my wood burning stove, some to stand up and others to position under the trunk so if my judgment was wrong, prevent the whole shebang from coming down and perhaps hurting me. Another consideration was that the section to remain on the ground was to shift south due to the position of the boughs supporting it.
So I did all the prep and as "the spot" was still too high, I did a cut 18" further out than needed, where I could stand on the ground standing on the north side.
When I finished the cut the root disk side went slightly down, and the remaining section moved south as envisioned.
Another section of the top part was taken off to have an escape route just in case, and then another one to have two to stand on. At this point I went to get the camera and did snap a couple shots, then the moment of truth. I made the cut in "the spot," and the section fell, but nothing happened. I stood there panting for several minutes and looking. As nothing happened and I was dehydrated, I started to walk to go get some tea. "Tic, tic," I heard and turned to find the stump vertical! The thing weights several tons and did not make a sound other than that "tic, tic!" I was expecting a WHAM! and the earth to shake, but nothing, and I did not see it going up...
I have no cognition of all that computing the brain did, just call it an "educated guess" as I have done others, but nothing this massive.
The stump is 3 feet across at ground level.
