I barely consider myself a woodworker/turner. I certainly do not consider myself a metalworker, so I am looking for someone who is a metalworker and would be interested in hiring out for a small job. Essentially, I am looking for some greatly oversized pen bushings. I made my own from wood, but they tend to wear out fairly quickly.
I need a set (possibly 2 sets) of aluminum bushings to help in a production type woodturning job. I can't draw on the computer, but I do relate to food well, so my best description is this...
Imagine a donut measuring 2.5" diameter x3/4" thick with a 1/4" center hole. Now imagine a smaller donut measuring 1" diameter x 1" thick with the same 1/4" center hole. Now stick them together into one solid piece so the smaller donut is sitting on top of the larger donut with the 1/4" holes lined up.
The completed "stack" will slide onto a 1/4" shaft. The 1" diameter will fit inside my stock, serving as a jamb chuck of sorts. The largest diameter will serve as an O.D. sizing bushing.
The second part of the set will be the same design, but the largest diameter will be 3" instead of 2.5.
These measurements are pretty close, within 1/4" or so in diameter.
Anybody interested in a small metal lathe job? If so, send me an e-mail with a phone number, or reply here and I will e-mail you my own phone number.
Corian (solid surface counter top material) will also work. Easy to get small pieces. Glues up easily with super glue. Machines like a dream. I've made bushings for pen turning and they have lasted for years. I've made pepper mills and pens of course as well as knobs. Too many parts to count.
I can get them made for you. (reasonable/cheap)I sent you a sketch of what I thought you need. If you can confirm my ?'s & your location, I'm sure we can work something out
