Need help with Poulan
Dinyar Chavda
I hadn't used my Poulan in a while, and I put in new fuel mix, and went out to cut a log. With some difficulty, I got it started, and sliced off one end of the log to get rid of the checking. I turned it off, and repositioned the log to cut the other side, and I could not get the chainsaw to run for more than a couple of seconds.
I have since replaced the sparkplug, and cleaned the air filter. It is now at a point where I can get it started and going with the throttle out. There's a little smoke as it runs, but the minute I push the throttle in, the engine revs up and then dies immediately. What is the likely cause of this, and, more importantly, what can I do to fix it? Or do I finally bite the bullet and get a Husky/Stihl?
TIA.
Re: Need help with Poulan
Dick Coers
I suspect the fuel line is cracked inside the tank. It will suck in air if the crack is above the fuel in the tank. The modern gas is not good on two stroke engines. I hear that a lot of pros are switching to the premix from the store. It has no alcohol, but does have stabilizers and synthetic oil mixed in for better engine health.
Chuck Jones - West TN
re-read your last sentence.
Sorry to be so blunt, but in my experience you can quickly spend more money in repair bills with a Poulan than it's worth.
Steven Antonucci
Ditto- nuttin' but gas and oil in my Stihl
steven antonucci
One large problem is looming. It is called ethanol in the gas. Find a place that will sell you ethanol free gasoline.
You probably are gummed up and possibly your lines are cracked. The ethanol is NOT good for small engines. You can get a clean-up and rebuild for not too much money. Around here it is about $40.
D. Hansen
Even more troubling is that EPA just approved a request to have the ethanol level increased from 10% to 15%. that will mean more small high rev engines will burn up and your older car will have problems as well. If you can pull the plug and look into the cylinder see if you can see any scoring of the piston walls if so don't bother with the repair.
Barry K Ward
I'v been using CS for well over 40 yrs and I have used more types than I can remember.I have a Stihl 045, Homelite C-72 just to mention a few,I have about 10 I think,including a poulan,and for the most part ANY CS is no better than the maintinace that is perforformed after each use.I don't know how long it set,but if it set for a long period you could have a gummed up fuel filter or it could have dirt in the carb bowl,which in turn is getting into the carb jet causing it to quit on you.So I would check those things out and even pull the carb off and clean it,or have it done and there is a good chance that will cure your problem.I have had several poulans and for the price you can't beat em.
bill Crommett
Whatever else you do, buy non-ethanol gas and get the premium grade. It has less additives that gum up the gas lines and carbs. I use premium non-ethanol in all my outdoor equipment and have had no maintenance problems in years.
mjonesrdg
Dinyar...the saw idles, so I would guess that spark is not the problem. Inadequate fuel supply is more likely. I'd pull up the filter from the tank, pull it off the hose and blow it out or replace it, then try the saw again. If that didn't cure it's ills, pull the hose off at the carburetor end and try blowing through it or tip it down so that fuel runs out of the hose. If the line is delivering fuel to the carb, as Barry says, take that off and apart, clean with carb cleaner, and try again. After that, a carb rebuild may be required. You can do it!
Good luck with it!
Keith Inscho
If a saw, or any other small engine, sits for long, the fuel lines to and from the carb and priming bulb can become brittle and crack or break off entirely. As already mentioned, it may be sucking air when you give it throttle and killing it. Inspect closely and tug on the lines to make sure this isn't the problem. On another note, if you decide to upgrade to a Huskey or a Stihl, you won't regret it.
jim miles - charlotte, N C|
Got a Poulan- had same problem- Agree with other comment- before anything else more complicated replace the fuel filter- small cylinder inside the fuel tank attached to tube.
do you use Stabil in the fuel???
Adrien
Walt Bennett
Walt Bennett
By my old guiding principle, K-I-S-S! Check the fuel filter, but I'll second, third or whatever that you've got a cracked fuel line. I had the same thing happen with a Stihl 250. The rubber/neoprene gets cracks over time and you loose vacuum (which sucks fuel into the carb.).
Got a partial solution
Dinyar Chavda
I had decided to take the easiest approach suggested by you guys, and replace the gas filter and check the gas line. So, I removed the gas filter from the Poulan, measured the OD of the line, and also took off the air filter to replace it. Given that I was going to go to HD/Lowes to get these parts, I figured I'd also do the same for an older saw that I had inherited (an Echo 302), which had not even turned over when I tried it yesterday. I cleaned off the air filter--it was dirty--and decided to empty out the fuel to see if I could find the gas filter (turns out it does not have one, it has a strainer that is hard (impossible?) to remove. Just for kicks, I decided to try to start it, to see if I could get rid of whatever fuel was left. Surprisingly, it started right away, and ran until it was out of fuel. Not wanting to look a gift horse in the mouth, I put fuel in, and cranked it a few times, and it ran just fine after a while, to the point where I was able to cut the log and get pieces for turning. Maybe it was the air filter. Maybe it was the fact that it was warmer today. I don't know. But I'm not complaining. I'll see if I can get a new air filter and a spark plug for the Echo, when I go to the store, but for now, I am a happy camper as I got in a good afternoon of turning!
Thanks to all for all your suggestions and advice. I will follow up on the Poulan, and let you know what happens. In a lot of ways I am a perfect example of the guy that John Lucas referred to in the earlier thread "Re: Making a perfect ball, and some thoughts (Long)", ie.e, someone who need to be taught maintenance techniques and sharpening. Heck, in India, where I grew up, I don't think I even saw a chainsaw, let alone learned how to use and maintain it.
But, thanks to you guys, as well as others on the Internet, I can learn.
One other item to check........
JamieDonaldson
..if it is running at low speeds but not able to run fast- the exhaust/muffler/spark arrester. They can become obstructed and will block the exhaust gas when attempting to run at higher speeds.
