jet lathe live center
Dennis
I have a Jet 1642 lathe, and want to make some special wooden cones for the live center in the tail stock...does anyone know the size tap i would need?...tks...Dennis
Re: jet lathe live center
3/4" x 10 tpi
Doc Green
A bottoming tap will be easier to use. ~Doc
Chuck Engstrom
Hi Dennis -- the Jet and Oneway live centers have 3/4-10 threads. As Doc points out, a bottoming tap would get you further into the wood.
Another possibility is to buy 3/4-10 nuts, readily available almost everywhere, and epoxy them into appropriate sockets in hunks of wood that you can shape as you wish. You can probably buy a lot of nuts for the price of a 3/4 tap.
Best--
Chuck
Dennis in Southern Oregon
Dennis, for a cheap tap that works well in wood, buy a a 3/4" x 10 tpi bolt and file or grind a few deep v-grooves more or less lengthwise in the bolt. Make sure the edges of the grooves are sharp so that they will cut. A triangular file or a Dremel cut-off wheel work well for cutting the groves.
DJG
Also on wormwood screws
Bill Howatt
I have had some trouble with the Oneway wormwood screws being a real bear to get out of some wood. I did the same groove trick with a Dremel-like tool on the screw and it works like a charm both on and off.
Bill
Chuck Jones - West TN
buy two 3/4 x 10 tpi bolts...
You will need to saw the head off one to hold the wood piece in the chuck while you shape it.
I just did a couple pieces for my live center last night and had to search half the shop before I found my cut off bolt.
Dave Gelnett
I picked up several nuts at Home Depot. They are in the drawers on the one end and I think they are called specialty nuts and bolts. They work great.
Dennis
picked up a couple of 3/4 x 10tpi bolts yesterday and going to try and cut them today and see how they work...I did check around and you are all correct, 3/4 x 10 tap is not cheap!...tks for the tip....be in the shop today...Dennis
