Positioning a lathe in the shop
wilbur
Like just about everyone, I have limited shop space, and so I put my lathe close to the wall. The other day, I ran into an issue while turning the inside of a bowl where I found that my lathe was so close to the wall that the handle of my bowl gouge could touch the wall. I managed to work around this, though.
But now I'm thinking I should pull the lathe out a bit. My lathe is heavy enough that I would like to do this once. Are there any guidelines as to what the minimum distance should be between a lathe and a wall?
Re: Positioning a lathe in the shop
Steven Antonucci
Mine is the width of a pushbroom + 6"
steven antonucci
John Veerkamp
The length of your longest tool from the center line to the wall. This would seem to cover everything.
Terry Quiram
Far enough so that you can get behind it to clean.
Richard Allen
Richard Allen
Some folks angle the lathe to the wall slightly with the headstock father away from the wall than the tailstock. The idea being that should a workpiece self dismount and impact the wall it will tend to bounce toward the headstock instead of back at you. By that same logic some folks put a "target" which is angled down.
Naturally a workpiece has never flown off the lathe on me :)
As I turn mostly spindles, take any advice I give with a grain or two of salt.
The center line of my lathe is ~27" out from the wall/window. This is enough so that I can get the shop vacuum "nozzle" behind the lathe and myself. It is also enough to put the stand for my dust collection "hood" behind the lathe as well the DC hose. I'm not really that limited by space - more by clutter :b .
Lyle Jamieson
Lyle Jamieson
As you found out the hard way it is more about tool accessibility then cleaning. Dont limit your shapes, or ability to use proper tool control techniques, by having your lathe up against the wall. Dont forget you will need to swing the handle of a boring bar a considerable distance in the back of the lathe to do hollow forms with undercut shoulders. The headstock can be close to the wall. (no tools need to be swinging around in back of the headstock) Pull the tailstock away at least two feet from the wall. All my lathes are on an angle or even "T" from the walls. Remember to leave enough room at the very end of the headstock end, so you can get the knock out bar into the headstock.
Jim Pugh
Wilbur, a thought from a different direction, suppose you turn your lathe 180� and move it out far enough so you stand between the lathe and the wall? As others have suggested, having the lathe at an angle to the wall might also be helpful. With the wall behind you, you can just turn around to select a wall mounted tool or if you can find the space, put a flat topped tool box back there.... Over the years I have had my lathe in just about every position the space allows and currently work with my back to the wall as suggested. It also makes it easier for me to see someone approach before they scare the water out of me.
Get your car jack to help move your lathe and try several different locations/positions over time until you find the one that seems to work best.
Carole Valentine
There are occasions when I run my lathe in reverse and turn from the back side. Something to think about if you have room.
walta
I like to put the head stock close to a bench against the wall. I often find myself working from the back side as I can see what I am cutting. I think it�s a left handed thing.
Walta
Thanks!
wilbur
Thanks for all the input. Unfortunately, the layout and size of my shop really limits my options for how I can set up my lathe, but you all have been really helpful, and have given me some options I hadn't thought of.
Car jack?
wilbur
How do you use a car jack to help move a lathe? I can see how a car jack will lift it off the ground, but that still leaves the issue of moving it where I want it to go.
Re: Car jack?
A Hydraulic floor jack has wheels. It allows you to lift one end which makes it easier to drag the other end. Of course I lift both ends separately and put homemade dolly's underneath. An admittedly slow process but it works well for the occasional move.
I've looked at the wheels made by Pat Johnson (I think that's who sells them) for the Powermatic. Simply step on a lever and it locks the wheels down for moving. I may order some this year. I could build them myself but it would take a lot of time which I'm quite short of now.
