Shopsmith lathe
I was reading an article this morning in Woodwork on Mark Lindquist. He started his career turning on a Shopsmith. I did also. Not trying to compare the two of us just wondering how may others started on one.
After owning one for about 5 years and still turning on one at my Dad's I'm convinced the lathe is the weakest part of that tool. The tailstock is way too flimsy and of course fixed in position since you have to move the headstock and headstock quill to tighten the work.
The minimum speed is too fast and the machine too light to handle the size work that they claim will fit on it. They do make a very expensive device to slow the work down. I'm pretty sure Rube Goldberg works for them as a consultant.
The tool rest support is the weakest part. It's cast aluminum and very thin. It chatters like crazy and is a pain in the but to adjust if you have to move it. You need an allen key to adjust the swinging and the height adjustment is the same as the table saw.
Still, I did a lot of work, mostly segmented, with that machine and it got me into this world.
I don't think I would be the woodworker that I am without it. I had a complete workshop in the back bedroom of a 2 bedroom apartment. I sealed off the door and had filters over the airconditioning return ducts. This room was 8 by 10 feet and I could cut up a sheet of plywood by myself using outrigger supports I built. I had the planer, jointer, bandsaw and belt sander attachments that all sat on a stand in the corner when not in use.
I told all of the neighbors that if they heard any noise to call and I would stop immediately. They never called. Even when running the planer. Maybe they were Deaf. Although we did hear a really strange crashing noise one night and went to check on it. The neighbors had set up bowling pins and were bowling in their hallway. OK this wasn't necessarily on the good side of town. It was in LA as John Jordan says. That's Lower Antioch for those outside Nashville.
