Bowl bruse/metal marks
Keith Inscho
I turned some green oak the other day and discovered some dark rings after the bowl started to dry. I am assuming it is stain from my gouge rubbing the wet wood. I have attempted some additional sanding but to no avail. Is there anything you can use to remove these?
Re: Bowl bruse/metal marks
Steven Antonucci
lemon juice might work
steven antonucci
it's how I clean my hands after I turn oak... also works great for detecting cuts!
S
david
I have encountered this problem on occasion, and frankly have not had much success removing the marks because the stain seems to have penetrated a bit and I did not have sufficient wall thickness. I suppose if you sand or turn away the stain area you could get rid of it that way. I am not skilled enough to say how this can be avoided. Fortunately for me, this does not happen too often. Now let me tell you about sandpaper causing heat stress cracks...
+1 on lemons.
Other than lemon juice, you can also try a paste of oxalic acid (found in "Barkeeper's Friend" among other things). You are chelating the metal (usually iron) and doing a little bit of redox reaction.
I have lemons handy most of the year for baking, so I use them. I also have Barkeeper's Friend - which I use for cleaning.
Terry Scott
Keith id get out the steel wool and vinegar and ebonise all the bowl
Those marks will go quite deep
and whatever you do there will be one patch that just wont come out trust me this is from experience l.o.l
Thanks Everyone!
Keith Inscho
Ill try the lemon juice first, then the barkeepers friend. If that doesn't work, ill try the ebonizing route. Been wanting to try that anyway. "design opportunity" ;)
Keith Tompkins
Re: Thanks Everyone!
Keith Tompkins
Hey Keith, The marks may be caused by the rear edge of the bevel rubbing against the wood. A solution would be to grind a secondary bevel on the gouge; that would put less pressure against the wood.The back edge tends to lever the cut out of the wood, the secondary bevel helps. A very sharp scraper may take out the marks, a light touch to prevent vibration.
All of the above may work. I'm with Kieth. Before you turn another bowl grind off the sharp corner on the bottom of the bevel if you have one. I've noticed that a lot of turners are now going to a very short first bevel including myself.
Tool Grind
Keith Inscho
I suspected the heal may be the culprit, as the dark rings are in the transition between wall and bottom. How much should be ground off? I'm thinking maybe a third of the way up the bevel ?
Keith Tompkins
Re: Tool Grind
Keith Tompkins
I think 1/3 would be a good start...you know, Keith, your bowls don't NEED a transition. Your problems will be less with a bowl with a smooth flowing curve. :D
Re: Tool Grind
Keith Inscho
Touche! Thanks. :D
Oxalic acid
They sell it in the hardware store as wood bleach. It's a white powder usually sold in little plastic tubs. Works like magic to get iron stains out of high-tannin woods.
Rick Davenport
As stated previously, those marks sure sound like compression marks made from the heel of your gouge.
They are a bearcat to sand out.
A bit of water to raise the grain will sometimes lessen the compression and make it easier to sand.
I wet it down. let it spin slowly until dry, then power sand with 2" disks.
I also have an old 3/8" HSS bowl gouge ground especially for tight transitions.
The sharp heel is ground off and the angle is steeper than all of my other gouges.
It has eliminated 90% of my compression mark problems.
R
