Re: Sanding Sealers
Jesper, Denmark
We have an ongoing discussion/experimentation on the subject of sanding sealers and bowl finishing here in DK in a local turning forum.
The base recommendation is to use a 1 lb cut of blonde shellac as a sanding sealer. That is 4 oz. of flakes to a quart of alcohol or 2 oz to a pint. If you use dewaxed shellac, you don't have to filter it.
The discussion on the shelf life and ease of dissolving the flakes center around the water content in the available DNA, which has 5-7% water. I have found a local source of Bioethanol in quart bottles. Since the bioethanol is produced as a fuel additive, it cannot be used as such with the 5% water content. So the bioethanol has had the water removed.
Normally, in my 40�F cold shop, it takes a few days for the shellac to dissolve in regular DNA. With the bioethanol, only 24 hours or so.
If ones concludes that the water has some effect on the shelflife of the mixed shellac, then the shelf life with the bioethanol should be better. In any case, the cost is relatively small, $3.00 for a quart of the bioethanol, so if you mix a small enough amount to last you 6 months, it's no big deal if you have to throw some away and make a new batch.
