I have a Nova 3000. I just found out that there is a vacuum adapter available for this lathe. The vacuum adapter fits into the hand wheel and it is intended to be used with a shop vac.
This adapter is essential a sealed bearing with a pipe attached to bearing. I am curious whether it is feasible to modify this adapter to be used with a vacuum pump by sealing the end and adding an air hose conenctor to the pipe.
Have anyone of you tried this? Please share with me your experience.
Yes it can be used that way. You will have to plug the holes in the pipe stem. I used flexible tubing (reinforced) attached to the pipe fitting and then to my vacuum pump. wrorks very well. The adapter is no longer made though.
I have a Nova DVR and bought a sealed bearing that slips into the hand wheel. I used the lathe itself to turn a brass fitting to slip inside the bearing and leave threads on the other end. Epoxied the modified fitting into the bearing after fastening the vacuum system to it. It just slips into the hand wheel. I put a big O ring into the hand wheel to improve the seal. It is snug and just stays in there and the vacuum sucks the bearing tighter and tighter against it. With the vacuum off, you can just slip the bearing out when you don't want to use vacuum.
On the Woodnet forum, a user mentioned that the Nova lathe is not designed to use with a "hard vacuum". He claimed that the "hard" vacuum can suck grease out the spindle bearing. However, I know OneWay makes a rotary vacuum adapter for the Nova lathe. This adapter screws into the outboard end. I do not think OneWay would make such an adapter if the Nova lathe is not designed to handle hard vacuum.
I am going to call Nova tech support to see what they say about this.
What size is such a bearing and what is the cost? The cost of the Nova vacuum adapter is about $30. One nice thing about this adapter is that I can reatap one of the holes on the pipe to accept a 1/4" NPT air hose fitting. This will be similar to the OneWay rotary adapter at 1/3 of the cost.
I have a DVR and I used the vacuum adapter that Packard sells. It works very well. It consist of a bearing which fits into the handwheel, a threaded rod and a fitting that fits into the spindle. You could use it on different lathes by changing the threaded rod. I don't have any affiliation with Packard, just a satisfied customer.
You can measure the recess in the hand wheel accurately and buy a sealed bearing at a good bearing house. I assume the DVR has the same recess as your lathe, but I don't actually know that. The best thing might be to take the hand wheel off and take it to a bearing house. They could fit the bearing to the wheel. I think I paid about $20 or $30 for the bearing, but there are many qualities available and many different levels of sealing them. I am nearly sure the bearing is metric, but that would be no problem for the bearing house, many bearings are metric now. My recollection is that the bearing house only had a much better bearing than I needed in stock and I paid for it thinking a bird in Hand...and I did not have to pay shipping.
If you use the O ring the way I did you don't need a perfect fit.
I can not imagine how this setup would suck the grease out of the bearings on the shaft. The vacuum is pulled through the shaft and is sealed in such a way that the pressure is inside the shaft and could not affect the shaft bearings outside the shaft.
When I had my Nova 3000 I never got the bearing that Nova supplies to provide an adequate vacuum with my Gast vacuum pump. I changed over to the EZ vacuum bearing (Like Packard sells) with the threaded rod (might be the same as a hollow threaded lamp rod) and got the setup to work reasonably well.
You can make your own adapter to go into the Nova hand wheel from wood (you are a turner!), a sealed bearing, a bit of closed cell foam and an fitting for the vac hose. Works great. I tried the thing with the threaded rod through the headstock and that was a royal PITA.
my own adapter. Sometimes I get trapped inside my own head and there is so little room in there for thinking. You are right. You (or I) could turn a ring to fit in the hand wheel with a rabbet or recess in it that would fit any smaller bearing that was properly sealed. Duh and double duh.
I did find that it was a good idea to remove the hand wheel and reinstall it with either pipe dope on the thread or an O ring behind it. The vacuum is tricky stuff and it will find any little leak. I also put a thin flat rubber gasket behind the faceplate because the threads on the shaft don't seal to the faceplate. Made the little gasket out of rubber tool box liner I found at Lowe's.
In order to get a good fit use some material that doesn't move with humidity changes. MDF, plastic decking, etc. If it's porous material at all cover it liberally with a good thick finish. You can also by bearings that are a snug fit for the NOva handwheel. Then just put a gasket on one side and fit something (I use plastic or brass barb fittings) in the inner race to connect the hose to. That's what mine is.
