I recently bought this Burnmaster handpiece for home-made brands and tips and just love it. You can really crank the heat and never does it get hot. You can also use the replaceable tips in it as well. The ergonomics of it are wonderful too. Just wanted to share!
I see this Burnmaster is available from Packard Woodworks. As a newbie to woodburning, do you recommend getting an assortment of 10 pen tips, or do you think its best to get into the shapes and profiles one or two tips at a time?
Thanks for the update on this new pen Jennifer. I was getting ready to purchase one or two of these but was curious about the heat transfer. You answered that question for me. Thanks for the timely post.
David My personal opinion is that you should get one or two and see how many different patterns you can create with them. I have about 10 but only use 2 or 3 90 percent of the time. There are an amazing amount of textures you can create with just one pen. Make dots, draw lines, draw cross hatch lines, draw curvy lines, draw curvy lines with a dot at the end, you get the picture. In this way they become background textures. You still have to create an overall design, such as Molly's horses, or some of Jennifer's patterns.
The other option is to custom bend your own to create some unique shape that you can use. This is what Molly and Greame Priddle do.
I looks like the handle is really large near the wire. Do you look around that to see the wire, or am I not seeing it correctly. I wonder about registering the wire for each burn and thought you would need better visibility.
Yup, I did Steve, but tha disc isn't a result of it. That's been laying around for weeks now. Another pounded out piece of copper waiting to be something. I did find some scrumptious jewelry though!
David, I would start off with only a few tips. The ones I use most are a small or micro skew. Some companies call it a 12s I think? I also use a ball tip a lot. they come in various diameters. I use 1/16 and 1/8 the most. I also use a handwriting tip but not for handwriting. I use it for texture only. I could never get the hang of writing on wood with it. I recommend the pens with fixed tips instead of the tips that are interchangeable in a single pen. I think you will have longer life from a fixed tip one piece pen because the you won't get a sloppy fit at the connection point which can ruin a burn real quick if the heat is coming and going. the handpiece that I show here is usable with the interchangeable tips and this is the only way I would go with those because you can tighten the grip on the prongs. the drawback is that it's a bit cumbersome for anything other than stamping or branding. I wouldn't want to have to burn long curves or small details with this handpiece.
Dick, I haven't noticed the flare at the top getting in the way. If I am looking to the side it might be a natural thing to begin with. I usually rlol my branding tips to make sure I get them where I want them instead of a true stamp.
Thats what I found I ordered a hand piece a year ago and its the only one I havnt been able to kill
The burners are great also as they give 130w of out put (although you have to crank them up to do this as they cannot be exported from the states over 100w easy to do with a small screwdriver
I was so impressed I just got in a shipment of them last week
A bit of a plug but I am the New Zealand agent if anyone needs any wood carvers supply burning gear down under
Steve I just photographed some Mokume jewelry. I think it was Nickel and copper. If I remember I'll post a photo when I get back to work. That will be a few days. Got to clear up some family stuff first.
I don't know if Jennifer met Bob Coogan while at the Craft Center. Bob is a master at Mokume Gane. He was showing me how to do it one day. He had this glowing red orange mass. He kept trying to show me how to see the melting differences between the nickel and copper. I could not. Must be my glasses. It all looked like a big orange blob to me. Apparently it's all in getting this temperature just right before forge welding it together.
I don't think it's hard to do, it's just an acounting problem. If you follow the steps, the numbers add up...
What I have been doing to work out the process is using a couple of dimes and a MAPP torch. The nice thing is that they have already welded the copper to the nickel for me, and all I have to do is weld nickel to nickel. (two facing dimes). I use a 3# hammer, but the real mokume folks use power hammers or hydraulic presses.
I have some brass and copper that I'm going to be mucking around with in the forge when I get a chance. The hardest thing is controlling the oxides. Dimes are clad with nickel probably in the range of 1-5/1000" , so you can burn up that material very quickly.
S
P.S. If you've never seen how they clad the nickel to the copper, it's awesome...
Since we're stealing techniques from metal working there's always niello to try. Used more for engraved armor and swords - but . . .
For the ultimate hollow form - why not electro form copper over a turned hollow form - that's been sandblasted to give a nice sufrace texture - then burn out the wood - leaving a very thin walled hollow form.. Once you've got the copper hollow form it can be patina-ed a hundred different ways, can be plated with nickel, silver or even gold.
Depending on how fast you plate the copper on to the wood, you can get a fairly smooth surface that follows the surface below it - or - a very nodular little bumpy surface. If you really want to go ape - there are low fire and high fire colored enamels you can try. And you can solder all kinds of shapes to it.
The set up can be cheap - a plastic 5 gallon bucket, some small copper tubing and fittings, some copper wire - and a battery charger. The plating solution can be copper sulfate you can probably get at a hardware store or gardening center and a chunk of copper plate for the anode.
If you want to get crazy - turn your piece then dribble or draw your designs in wax - then do the electro forming.
