Veritas - Innovation in Tools
My Rikon 18" bandsaw is in limbo
Starry S Chan
I would like to share with you my experience regarding Rikon tools.
I bought a Rikon 18" bandsaw from amazon.com during the Thanksgiving holiday. It was delivered within a week.
The packaging is extremely poor. During shipment, this bandsaw probably fell flat on the motor side or something fell onto it. Because of this, the blade tracking wheel was shattered into pieces and the motor fan shroud sheared off one of its mounting screw. A few of the fan blades were nicked and fractured at the blade junction to the plate. The front blade guard was not secured so the clear plastic was cracked and the surface was badly scratched because of its contact with the upper wheel housing.
I e-mailed and contacted Rikon this past Monday and I talked to the VP of Customer Support and Technical Support, Rod Burrow. He may be the only person working in this department. I subsequently called and e-mailed him a few times. I never got a commitment from him as to when the replacement parts will be sent to me. I did not receive a reply on any of my e-mail messages.
I never understand why tool manufacturers are so cheap regarding packaging. If Rikon has properly packaged its product, they would not have to send me the replacement parts at their cost. I also would not have to spent time to install the replacement parts.
In any case, I do not want to use this bandsaw until it is whole. Otherwise, amazon may not accept it as a return. I also have a concern of regarding the quality of Rikon custom service. If the motor went out a year down the road, can I count on Rikon customer service to send me a replacement motor promptly so my bandsaw will not be out of service for a long time?
What would you do if you are in my shoe? Would you return it to amazon? If you return it, would you want to get a second one knowing that the same thing may happen because of the poor packaging. I told Rod that I have to have the parts to make this bandsaw whole no later than Christmas as I have 30 days to return the product. I did not get a reply from Rod to assure that the replacement parts will be sent ASAP and the parts will arrive before my return period expires.
What is your experience with Rikon Tools?
Starry
Re: My Rikon 18" bandsaw is in limbo
Rick Allen
Send it back. You bought a new saw and it should be a new saw.
If you can I would get the saw from a store. The saw will arrive at the store and the store will not release the saw to you until they have a saw in new condition.
It isn't just the parts. The frame for a bandsaw is critical. If the frame is bent even slightly you will never get the service out of the saw that you should expect.
Service is worth a lot. Because the saw is new that service should be provided by the seller not the manufacture. Let the seller work out"issues" with the manufacture.
Good luck
I bought the 18" Rikon a number of years ago (not from Amazon). I didn't think the packaging was that bad. Ir arrived reasonably securely packed in a crate. It took me a while to disassemble the crate.
I've ha reasonable luck with Rikon's technical service. They were quick to help me with replacement bearings for my guides.
If the crate was damaged when you received the saw, why did you accept it? You should have had the option to refuse the shipment. The carrier is responsible for getting you the piece in good condition.
david
I got the Rikon 18" bandsaw from Woodcraft about two years ago, based on the positive review in Fine Woodworking magazine. The motor went out within a couple of months. I contacted the technical support department, explained what was happening to the motor, and was told I needed a new motor and one was being sent. Now, you need to live in the middle of the Pacific to know what difficulties you can experience in delivery of anything. But as I recall, the motor arrived promptly and when I asked about the one that was replaced, I was told to keep it or do whatever I wanted with it. Eventually it went into the trash. No complaints about customer support, but I am not that high on the saw. I guess you get what you pay for.
bill Crommett
As JL says, it should have been refused. A number of years ago I refused shipment on a Delta table saw from Woodworkers Supply because of a bent switch attachment that I could have easily fixed. But it was minimally packed, and the replacement was much better packaged when it came. It shouldn't be up to the consumer to teach the shipping people how to package their merchandise, but it is the way the world works.
Starry S Chan
These are concealed damages. Looking at the outside of the crate, if you can call it a crate, I could not have seen the damages.
Starry
Starry S Chan
I probably should have bought it from WC. I actually do not know whether WC will uncrate it to verify the package content.
I did not save much money by buying it from Amazon. However, the nice thing about buying it from Amazon is that the delivery is to the floor of my workshop instead of to the back of my pickup. This makes a big difference as bringing a 500 lbs uncrated bandsaw from my pickup to the floor will be a challenge.
Starry
Walt Bennett
Walt Bennett
I've bought several large tools from Amazon with no problems, and none were Rikon, so I can't speak to your experience directly. I know Amazon is very good at customer service though, even when items are direct shipped from manufacturers or distributors, and I don't see in the thread that you've complained to them about the damage OR the pathetic Rikon customer support. I'd suggest you get Amazon to put some pressure on Rikon also.
adrien Coblentz
That's an awful lot of work you're setting yourself up for if you repair the saw.
Returning it and getting a working unit makes a lot more sense to me.
The comment about a bent frame hits home.
Steve Kubien
Steve Kubien
Send it back, without question. Your is not going to be a new saw. It is going to be a repaired/refurbed saw.
Barry L Elder
I agree with JL in that the freight carrier has prime responsibility. That's probably why you have not heard from Rikon. Rikon is probably contacting Amazon and the freight carrier to take care of the problem. It doesn't matter whether you could see the damage or not. File a claim with the carrier first.
Steven Antonucci
The value of brick and mortar
steven antonucci
My personal opinion is that this is the value of a brick and mortar shop. Sure, you probably would have paid a bit more, but think of how much time you would have saved if it had been purchased at your local Woodcraft?
When I bought mine, we opened the crate to do a quick inspection. The guy at the store actually went inside to open up other tools to help me remove some of the tailgate extended so it would fit in the back of my truck (I had 1/2" to spare). He helped me tip it carefully, as if it were going to his place instead of mine, and we got it all loaded without issue. It was 20 degrees outside, but he took the time to make sure it was done right.
When my Rikon bearing guide broke a couple of years ago, the Woodcraft guys helped me navigate to Rikon tech support, and I had a part for it in a week. (CA glue actually held the broken parts, but I digress).
If it were me, I would send it back to Amazon and rebuy it from a local entity where you could see it before accepting delivery...
Steve
Katherine Kowalski
Katherine Kowalski
I've had several opportunities to contact Rikon customer support, and each time they have been very helpful. I use two Rikon mini -lathes for my production work, and have had parts replaced with no problem at all. (The parts were sent immediately; the lathes were still under warranty). At some point my Rikon bandsaw motor went out, (I have a 14"), and they sent a replacement motor immediately. I've been VERY happy with Rikon customer service.
However, the issue here is that you received a damaged product -- send it back to Amazon. You purchased the product from them, they have the responsibility to send it well-packaged to your doorstep. THEY can file the complaint with the shipper.
Katherine
Not So Fast...........Return The Saw.
Barry
I would insist on returning the saw for a new one. The problems with shipment and what may have been improper packaging should be sorted out between the company and the carrier. You had no part in it. Don't become a part of it. There may be unseen damage, misalignment or other problems. The last thing I would want would be a brand new bandsaw with a blade that wouldn't track or some other problem. You bought and paid for a brand new saw, not a reconditioned one or a scratch and dent. I would hesitate to do anything but the most minor work on the bandsaw for fear of voiding the warranty. Just my opinion.
