Veritas - Innovation in Tools
Cocobolo Box
Cocobolo Box
Cocobolo Box
Harry in Beautiful Downtown Kulpsville
I am turning a small, lidded Cocobolo box as a Christmas gift. I am in a quandary as to what sort of finish to use. The wood is so oily but I'm not sure if a surface finish would actually adhere to the wood. And, I am reluctant to use an oil finish because I feel that it would muddy the grain.
Any and all suggestions will be appreciated, Harry
Re: Cocobolo Box
Re: Cocobolo Box
charlie belden
Try running through the grits to 4000, 8000 even better. Then polish it with a coffee filter. You may find ANY applied finish isn't needed.
Re: Cocobolo Box
Re: Cocobolo Box
Ken Bellock (Houston, TX)
I recently tried experimenting with a couple different finishes on cocobolo bottle stoppers. They all seemed dull compared to my usual cocobolo finish which is a beall buff. Unfortunately the wax finish doesn't seem to hold up well to heavy handling and time spent in a fridge.
Re: Cocobolo Box
Steve Kubien
which wax?
Steve Kubien
Ken, which wax are you finding breaks down in the fridge and via handling? Beeswax, microcrystalline, paste wax? Just curious as about the only wax I ever use is microcrystalline and things like coloured paste wax.
Re: Cocobolo Box
Re: which wax?
I use the Carnauba wax bar that comes with the Beall Wood Buff kit. It looks absolutely gorgeous after the buff, but doesn't last long. Especially after a night in the fridge, it looks cloudy after that.
Re: Cocobolo Box
Re: which wax?
I know that wax will water spot. Perhaps these items, since they go into the refrigerator at room temperature, collect condensation as they cool. This might manifest itself as a cloudy surface appearance. Have you tried buffing these again?
Re: Cocobolo Box
Bob Moffett
Re: Cocobolo Box
Bob Moffett
I have used Deft gloss lacquer before. It worked very well and really brought out the grain.
Re: Cocobolo Box
Re: Cocobolo Box
Carole Valentine
Harry, I have used Waterlox...sand to as high a grit as you have got (I went up to 12,000 micro mesh) then just wipe on the Waterlox, wipe off to as dry as I could get it, let it sit for a day, then buff. Looked great and did not seem to muddy the grain,but your results may differ. If it is all heartwood you may only need to do the super fine sanding then the buff.
Re: Cocobolo Box
Re: which wax?
When I pull the stopper out of the fridge there is a layer of condensation on it. If I take it back to the buffing wheel, I can brighten it back up a bit, but that's not something available to most people I give these away too...
Re: Cocobolo Box
Re: Cocobolo Box
Thanks folks for all your suggestions. I believe I will sand out to my finest grits and then Beall buff with Tripoli and White Diamond but omit the wax. If I like the finish after a couple of days, I'll leave it that way. If not, I'll take Carol's suggestion and use a thin coat of Waterlox. Thanks again!
Harry
Re: Cocobolo Box
Re: polishing of Cocobolo
Henry (Raleigh, NC)
I have no experience with Cocobolo, but I seem to recall someone writing here that they regretted using white polishing compounds on dark turned pieces (can't recall their finishing schedule). If the white polishing compound lodges in any grain or crevice it will be very visible and difficult to remove.
It's not that I expect your fine turnings would have any defects or crevices, but mine would, so that advice stuck with me.
Henry
Re: Cocobolo Box
Re: Cocobolo Box
Carole Valentine
Harry, I do not use the white diamond on it.
