About 9 nears ago I sawed several hundred board feet of some exceptionally nice red oak and stickered and stacked it in an unused hay barn. A short while later I realized it had been invaded by some type of insects. It now contained a large population of holes about 1/16" diameter. I realize "wormy solid" is an accepted classification for oak, but I don't care for it. So I more or less abandoned that stack.
Four years ago I used some of this lumber to make a lower shelf for a work bench in my new shop. Last week I noticed little piles of fresh sawdust on the floor under that shelf. Realizing that I don't have the cleanest shop in the county I brushed them aside and didn't think much more about it. Couple days later, there are more little piles of sawdust. Those suckers are alive and well.
My shop is virtually airtight, heated and air conditioned. The nearest water is twenty feet away. I fumigate the shop at least once a year with something strong enough to kill spiders and other common insects.
Any ideas on how I can get rid of these little devils? I may just have to yank these boards out and replace them.
Well you have to realize the piles of dust are caused by the adult insect leaving the wood to go and mate and lay eggs so that the minute larvae can then burrow into the cells of the wood and repeat the process. So easy way out is too destroy all the wood by burning and then fumigate the whole shop. Fumigation does not penetrate very deep into wood so will not kill the critters already munching away deep inside. A surface coating might deter them exiting for a while, but they will still keep munching. Try a gasoline or paint thinner wash on the boards before using them. Keep them wrapped tight in plastic afterwards to see if there is any activity. But get the ones you have already used out of your shop ASAP
Years ago I had a friend who had the same problem with a wood-frame sofa made from beetle-killed pine. If you had a way to raise the temperature to, say over 150F for a prolonged period of time (I assume you don't have a microwave big enough for boards!)...say a full day... it would probably kill the bugs.
With any luck, they are specific to oak and won't find your softwood floor joists palatable.
You have powder post beetles. I have heard that boric acid powder will take care of them, they track it into their holes and it kills them. Other than that, burn it.
Sounds like your lumber has powder post beetles. They seem to prefer hardwoods, and especially fruitwoods. We had an infestation that burrowed into hard maple flooring. Those little holes and sawdust piles are a classic symptom. The exterminator treated them twice, and I think they are finally dead, but they were really stubborn, and I understand they are very hard to kill off. If it were my house, I would run, not walk, with that lumber to the burn pile and enjoy the heat on a cool evening.
You have Powder Post Beetles. Go to WoodWeb and look them up.
The treatment for them used to be to tent and gas the house with Methyl Bromide or Viacane. Both very serious poisons and a very expensive process. Now the pirates are the answer. You can buy either TimBor or BoraCare. Timbor is a powder you mix in water and Bora Care is a thick syrupy liquid. Actually glycol with the borate suspended in it. You water it down 50/50 and spray it on. The claim it will penetrate to the center of a 12" x 12" beam. The last gallon of Bora Care I bought was close to $100. I like it better than Timbor. The specs on Timber call for two applications and it leaves a white powdery residue on the surface. Bora Care only call for one application. This is assuming there is no finish on the lumber. The borate is nearly harmless to humans, but the glycol is a different story.
Chuck, I once had a similar problem except the bugs were boring in a new ash paneled bathroom. I got a needle and hypodermic syringe, filled it with a strong malathion solution and injected each hole. Every week the number of holes and bug dust diminished. I continued to inject the holes until I killed all the bugs. Never had another problem.
