200+ woodworking book reviews
Favorite live centers (and sources)?
I have a Jet cone center - it came with my lathe. I use it as a "jam" center mostly. It fits in the holes quite nicely.
I have a Sorby Steb Centre. I use this with most of my spindle turning.
I have to trim spindle ends on occasion. It would be nice to have a live center that would accept a sacrificial piece of wood so that I could trim "into" the sacrificial piece as opposed to a piece of metal.
Re: Favorite live centers (and sources)?
Ken Vaughan
Ken Vaughan
My one-way live centers have a 3/4 by 10 thread on them. I got a tap at NAPA for a few bucks and thread pieces of UHMD plastic to thread on and shape them to function. there are a few tricks - I usually put the pin in to lock the shaft on the live center and then install it in the head stock to shape the auxiliary end.
Some of the wood I turn is harder than aluminum and I have considered milling some aluminum bar to use the same way.
The center point on the one way is MT1 and I have also looked at using the metal lathe to make a wider assortmetn of tips -- but work and life get in the way.
Jim in Burlington Ont.
Oneway Live Centre
Jim in River Oaks, Ont.
I have the Oneway, it's available in many places. I use it on my General and my Jet Mini, It's excellent!
take care,
Jim
JL I love my Nova live center. The tips are removeable and have a short #2 morse taper. I just turn a morse taper on a piece of wood and then stick it in the headstock. Well drive it in is a better word for that. Then I turn whatever shape I need for the tailcenter. Then I remove it from the headstock and cut it down in length until it fits the Nova center. It works great.
The center also comes with a center that has a screw thread. Anyting you can adapt to this screw thread ( think it's 5/16 bolt thread but would have to go measure to find out.) you can screw on the live center.
Mike Mills
Mike Mills
I have the Nova like John has. His pic with the lag screw is called a threaded insert I believe. I use t-nuts recessed in the back with the screw already threaded from the underside of the t-nut. Just thread the bolt into the threaded insert, bring between centers, and turn whatever shape you want.
Oneway
Ken Bellock (Houston, TX)
I bought the Oneway at the majority recommendation of this group when I was looking for a better live center for turning pens. I love it.
Ken
Chuck Jones - West TN
Plus 1 for the Nova Live Center Like John's
Bill Blasic
Re: Plus 1 for the Nova Live Center Like John's
Bill Blasic
Another vote for the Nova as I have a couple of the Jets and a couple of the Nova's.
Bill
Re: Oneway vs jet
Wayne Kuhn
Can anyone explain the difference between the Oneway and the Jett Live centers?
Other than one is black and one is chrome? Inquiring minds want to know.
Re: Oneway vs jet
They are virtually identical so I would have to assume it's the quality of the materials and bearings. I'm not a betting man but I would bet that Oneway uses better materials.
